Doors close hard
Old Apr 18, 2010 | 10:04 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Doors close hard
Ever since I got my camaro, you have had to shut the doors fairly hard to get them to close all the way.
What tricks are there to making them shut better?
Also my drivers window rattles inside the door sometimes when all the way down, and always does it when its all the way up, i hit the button down a little and it stops. drives me crazy!
Old Apr 18, 2010 | 10:26 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Doors close hard
I don't know much, but maybe your doors are sagging. If they are, they might require more of a slam to get them up and onto the latch.
Old Apr 24, 2010 | 12:32 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Also make sure nothing is blocking the door vents near the latch bolt. Those let the air pressure go somewhere.
With the window noise, it might be misaligned windows. If your windows are adjusted to far up, they will be too far in. The act of closing the door will require forcing the glass outward.
Kevin D.
Old Apr 24, 2010 | 02:51 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Be sure the door hinges are good and that the doors are properly aligned.
Old Apr 24, 2010 | 02:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by IROCK ZZ
Also my drivers window rattles inside the door ....
In the link below, there's a ton of info for eliminating noise in the doors:
https://www.thirdgen.org/forums/body...servation.html
JamesC
diana227vegas
Jul 8, 2016 12:27 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
tecustomz
Aug 16, 2015 02:28 PM
