Door mounting adjustment help please [pic]
Old Apr 21, 2010 | 01:23 PM
Frenchican's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Transmission: 5 Speed
After I had my car painted a couple years ago, I was ok with the misalignment of the lower rear door. Now... it bugs he heck out of me. I took it to a body shop to see what they would charge and was told it was an easy fix.
So, thinking I'd do it myself... can anyone give me some advice on what to do?
Here is a pic.
Old Apr 22, 2010 | 03:00 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Door mounting adjustment help please [pic]
Are the hinge pins in good shape? If the lower ones are totally shot it could cause the bottom of the door to stick out a little. The hinge is welded to the door so no adjustment there. You can adjust the striker but it may cause the top of the door to sit recessed compared to the quarter panel.
If the hinges are good, the door could be bent slightly.
Old Apr 22, 2010 | 03:10 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Oh and really nice car by the way!!
Old Apr 23, 2010 | 10:13 PM
bmad's Avatar
Car: 1985 Pontiac Trans Am
Engine: 383 Chevy
Axle/Gears: Ford 9 inch, 4.10 gears, Det. Lockr
I think I may have the same problem with my driver side door, I have replaced the bushings and pin on the bottom but I think the top hinge is the culprit. This could be the same issue that you are having frenchican. I don't know how to fix that top hinge, anyone have any suggestions?
Old Apr 24, 2010 | 08:04 AM
howy03's Avatar
I had both doors of and rebuilt the hinges I canot see doing it on the car my drivers door lined up perfect.I had to slot the passenger side body side hinge to properly align my door it was way off.The problem is if u adjust the door back u may have to adjust the front fender,hood,and nose in order to get the proper gaps.Mine was a real pain in the but to get perfect.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
