Rear Quarter Panel adjustment
Old Apr 29, 2010 | 08:41 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Transmission: 700 R4
So I was working on the Firebird yesterday and noticed that the passenger quarter panel is off a bit from the Drivers side. I checked all the lines on both quarters and it seems there is no damage.. Looks like it might have been like this from the get go. Any way I did a search on here to see about adjusting it but found nothing. To cut this short can I use a rubber mallet and straighten it out or will that seriously damage the quarter panel???? I can adjust the rear light a bit but it will still be off. Here are some pics.
Old Apr 29, 2010 | 09:13 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Rear Quarter Panel adjustment
Its hard to tell from the pic but are you talking about the gap between the lights and the quarter panel? Maybe you can loosen the brake light assembly and move it over slightly. I dont know if this is even possible but its just a suggestion. You might be able to bang it over but to me that is risky. I think a good body many might have the tools to do it properly.
Kevin
Old Apr 29, 2010 | 09:55 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Our cars are unibodys, which in this case technically means we don’t have ‘quarter panels’. The reason I make the distinctions is because there’s no way to loosen the panes and reposition them. If there’s an issue with alignment the correction must be made else ware, in this case probably the taillights or the rear hatch depending on what you were referring to. Hope this helps.
Old Apr 29, 2010 | 10:01 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Thanks I will try adjusting the bumper and tail lights themselves... Probably to risky to hit it with a rubber mallet. Don't want to make a little thing into a Big one...
Old Apr 30, 2010 | 03:48 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I agree with you. And you can adjust the hatch too. Good luck.
Kevin
Old Apr 30, 2010 | 07:38 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
https://www.thirdgen.org/hatchalign
Old Apr 30, 2010 | 09:14 PM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
thanks!
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
