Floor Pan same from 82-97?
Car: 1986 Iroc
Engine: 355ci
Transmission: 700-R4
Axle/Gears: 2.73:1
Hi Guys,
I was searching around the internet and stumbled upon someone that believed the floor pans were the same for 3rd and some (up to 97) 4th gen Camaros...
Is there any truth to this? I need a floor pan on the drivers side for my 95 and no one sells reproduction floor pans for 4th gen Camaros...
Anyone had this issue before?
Thanks!
Thanks!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Floor Pan same from 82-97?
the rear, after the back seats is similar if not the same, but the firewall back is totally different
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It isn't true. They look similar but they are indeed different.
Car: 86 Trans Am
That's the way to go. This way you keep all the factory contours in the floor pan. I can't stand it when I see plain sheet metal just welded in place. It works I guess but it isn't the right way to do things. A hack job repair at best.
skinny z
Oct 5, 2015 06:23 PM
