Sagging front end?
Old May 16, 2010 | 06:57 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Sagging front end?
So I have started prepping the nose and noticed that the top left of the headlight bucket sags inwards and is not straight. The nose is not original its a replacement part that replaced the previous one that I am guessing was cracked by a small impact when the previous owner had it. So what would be the way to fix it? First thing that came to my head was to heat it with a heat gun and try to get it back into shape. Any ideas?
Here are some pictures:
Nose itself:
The sag area:
Driver side which looks fine:
Old Jun 4, 2010 | 07:47 PM
Carlos773's Avatar
Re: Sagging front end?
bump, any suggestions/ideas? I am about to just wait and get a used replacement.
Old Jun 8, 2010 | 06:42 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
I used to know a guy that had this problem with a Firebird front end. After various failed attempts, what worked for him was using a thin aluminium sheet under the affected area which was bent to the correct shape of the front end. Not sure how he actually fused the two together, but perhaps a strong glue?
Old Jun 8, 2010 | 07:11 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
I've heard of people using a heat gun to repair badly bent air dams, so I wouldn't be surprised if it could work on the bumper. I guess there's a chance you could ruin it, but if its already ruined, why not take a chance?
Carlos773's Avatar
I tried using the force of the bolts from the bumper/fender themselfs and that fixed some of the sagging but the ''lump'' is still there. I might run with this nose for now and will find a replacement for it later on or if one pops up at a local yard.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
86IROC112
Apr 9, 2016 10:20 PM
bellez77
Sep 5, 2015 08:39 PM
