Hatch glass frame painting
Old May 19, 2010 | 06:17 PM
captain.spauldi's Avatar
Car: '86 Camaro
Engine: 2.8 V6 TPI
Transmission: 5 spd man
The frame around the hatch glass on my camaro is all rusty & needs painting. I've never painted any part of a car but want to start, so I'm looking for some advice on where to start ie materials & techniques can anyone help?
Old May 19, 2010 | 06:41 PM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Re: Hatch glass frame painting
Couldn't say the same thing I need to change my windshield on my 85 camaro with the right one which i got and the one i got is 86 with those big holes! But the same thing is that my hatch trim is all rusted any advice to clean that up??
Old May 19, 2010 | 10:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I just did mine - not absolutely perfect, but looks damned good. I took the blue painters tape (WalMart), and taped everything off, just getting the edge of the tape up under the metal edging. I taped a good 6 inches on either side, then I taped newspaper all over everywhere else ('cause I know I'm accident prone!). Then, I took some 220 sandpaper and saned down the edging smooth. Then, a foam-tipped brush and a small can of Rustoleum Satin Black. Let it dry a day (was really humid here), and it turned out really nice - only if you put your nose on it can you see the 'stroke marks' - I think it helped alot to use the foam brush, and I kinda put it on thicker than usual so that the stroke markes would 'blend' with gravity.
Old May 20, 2010 | 05:33 PM
FryeDaddy's Avatar
Ok cool, Imma do that when ever i got time ( I better check the weather before doing so cause it just rain real hard today)
Oh yea today i tried taking my hatch off then i found out my key the guy gave me isnt the right one to unlock the hatch. So what can i do to take it off without having a keysmith coming in to unlock my hatch (i can unlock all other doors of my *85* camaro but not the *86* hatch)
Old May 21, 2010 | 07:40 PM
Car: '86 Camaro
Engine: 2.8 V6 TPI
Thanks for that dude, gonna have a go tomorrow as it's forecast good weather. @Fryedaddy: You could just swap the lock cylinder from your old hatch?
Old May 21, 2010 | 07:56 PM
camarofanatic90's Avatar
Car: 1990 Camaro RS
Engine: soon to be 383 stroker
Transmission: t5
Axle/Gears: soon to be 3.73
the lock isnt on the hatch its behind liscense plate on car someone may have changed it out
Old May 22, 2010 | 12:51 PM
Car: '86 Camaro
Engine: 2.8 V6 TPI
sorry I completely misread the post, what you can do is lean in the trunk for the inside of the car, remove the trim from in front of the latch and you can operate the lock cylinder with your fingers, once open you can then get ahold of a new lock cylinder and swap them.
Old May 23, 2010 | 03:02 PM
FryeDaddy's Avatar
Ok I just check to see if i could do it from behind and no success unless i want to tear up my plastic cover in half. The key lock is located behind liscense plate as well. Now i need to know how can i remove the plastic cover without tearing it up. Ill let you know if i found any progress in doing so. Also I am going to change my windshield of the hatch what stuff is needed when changing the windshield? I know im going to need some sort of trim and weatherstriping on it can someone find out what they are call exactly?
Old May 23, 2010 | 06:49 PM
Car: 1992 RS
Engine: Carbed 350
Yeah - there are a couple screws in the top of the plastic that hold it in, and you can't get to them with the hatch closed.
Old May 24, 2010 | 06:05 PM
Car: '86 Camaro
Engine: 2.8 V6 TPI
I used your method camaronewbie, really appreciate the advice......did my first ever bit of painting today and it came out awesome!
Old May 24, 2010 | 07:01 PM
Car: 1992 RS
Engine: Carbed 350
Glad it worked out for you - I wouldn't go crazy and paint the entire car that way, but it works for the little trim pieces here and there.
I also got a rattle can, and removed the plastic cowling above the windshield wiper motor, cleaned and sprayed it as well. It's amazing what some small little touch ups can do. If you do this, be careful of the windshield - I slipped with the pry tool I was using to pop the tabs on the cowling out, and caught just under the edge of the windshield - needless to say it cracked from the bottom to the top, and I had to spend $160 on a new windshield {I wasn't happy, but you gotta laugh these things off}
Old May 25, 2010 | 12:33 PM
FryeDaddy's Avatar
Ok now im stuck i cant get the cover off because it has to be open to do so, but my key does not work on that key lock help?!?
Street Lethal
Apr 30, 2019 12:14 PM
Uglybronco
South Central
Oct 25, 2015 09:22 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
zayne0
Aug 24, 2015 07:22 PM
BrianI
Aug 9, 2015 11:52 AM
