Squeaking coming from around D/S mirror; don't think its the mirror.
Old May 29, 2010 | 09:24 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I have had a squeak near the driver side mirror since I got the car. Today I took the door panel off and attempted to tighten the mirror down; It tightened a small amount more and I test drove it; the squeak was still there. Upon further investigation, I noticed that its coming from the door, right at the corner near where the mirror attaches, but its not actually the mirror. Has anyone else encountered this? If you push on the corner of the door in front of the mirror, the squeak starts.....
Any ideas would be great; my passenger side is quiet, I'd really like the D/S to be as well!
Old May 29, 2010 | 09:41 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Squeaking coming from around D/S mirror; don't think its the mirror.
Have you tried driving with the panel off to see if it squeaks . if it doesn't I would say your panel top with the window sweep is vibrateing causing the skueak . Or if it still does it the window triangle could be the cause .
Old May 29, 2010 | 11:09 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Yeah, I was driving w/o the door panel on.
I think its actually the weld that connects the skin to the actual door structure. There's noticeable flex on the door skin at that point on the drivers door; whereas the passenger door (which doesn't squeak) is tight.
Old May 30, 2010 | 07:45 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Thats probably it then .
Old May 30, 2010 | 08:03 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Any idea if thats common?
Old May 30, 2010 | 08:29 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
No idea . I would say just vibration or warpping could cause the seam to come loose .
Old May 30, 2010 | 02:38 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I was in the same ballpark. Took the panel off to tighten the mirror also.. No dice.Then I looked at the door skin and its got a small crack to the front I'm thinking thats what it is.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
