Are my Hood Hinges worn out? One side hangs up?
Old May 31, 2010 | 07:43 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I think I know the answer to this.. But when I lift my hood one side will raise before the other side in the rear and kinda put it in a bind. Then I got to kinda twist it so the other side will start to come up. The lift supports work and hold the hood up. So I'm thinking the hinges have to much slop. Any ideas?
Old May 31, 2010 | 07:48 PM
molnarzack's Avatar
Engine: 305 tpi
Re: Are my Hood Hinges worn out? One side hangs up?
mine do the same thing>.> i jsut got used to it lol but i would def like to find a fix.
Old May 31, 2010 | 08:00 PM
Transmission: 4L80E
Yea I'd hate to paint the car and it binds up and nicks the fenders. I'd cry
Old May 31, 2010 | 08:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
a good cleaning & re-lube of all pivot points will do wonders . i'm not being sarcastic , i have been there . i haved used wd-40 to clean all ( ALL ) pivot points & white lithium spray to lube . clean well & re-lube . good luck .
Old May 31, 2010 | 09:26 PM
Transmission: 4L80E
Well I've done that before but didnt use lithium. WD40 helped a lil but wasnt a 100%cure
Old May 31, 2010 | 09:49 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
also check to make sure that with the initial bind it hasn't bent your hinge outa shape just a little. my new 87 model had this issue and I did the clean and relube but it still bound, found the rear bar bent just ever so slightly, and after straightening it works wonderful.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
86IROC112
Apr 9, 2016 10:20 PM
LittleFranks
Aug 20, 2015 03:55 PM
Randomtask2
Aug 13, 2015 01:57 AM
