Guess My Weight!
Old Jun 1, 2010 | 08:24 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Guess My Weight!
87 base firebird carb V8 auto
windsheild washers and wipers delete
no front/back steel bumper
pin on fiberglass hood(hinges delete)
AIR delete
EGR delete
AC delete
K&N extreme air filter
hooker 2055rs
SLP loud mouth for 4thgens (the single 3" glasspack into 2 2.5'' tails)
PW&hatch
4th gen T/A wheels
no pass seat,no back seats, no center console, no carpet, no plastics or headliner
no spare tire/jack
no radio/speakers, hvac controls
02 SS rear with girdle and tubular control arms
aluminum driveshaft
how much should it weigh??
(driver lost 30lbs and still diet/ exercising)
Old Jun 14, 2010 | 11:55 PM
Re: Guess My Weight!
ttt
Old Jun 15, 2010 | 02:13 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Not a weight expert, but 2950-3250?
Head to a local scrap yard and use their scale.
Old Jun 15, 2010 | 07:30 AM
cool i ballparked it @ 3100ish
Old Aug 8, 2011 | 07:50 AM
made some new changes, check first post ttt
Old Aug 8, 2011 | 07:56 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Somewhere around 3100ish... My Formula (5.7 auto) weighed in at 3290, with weight reduction being no spare tire, Fiberglass wrap around spoiler, Washer fluid container delete, Aluminum heads, and stock al driveshaft... But then I added sub-frame connectors, and heavy leather power 4th gen seats. But then again, for what I have read and compared to, my formula was on the lighter side.
My goal is to be around 3150... I am going to get an Aluminum powerbulge hood, lighter seats, aluminum front bumper, Lighter wheels, Delete the AC, and drill some holes and lighten my doors.
Old Aug 8, 2011 | 08:04 AM
build sheet said i was 3250 out of the factory door, ive easily taken 100lbs off the nose of the car it sits up a full 2" from where it was, im actually contemplating some 18" rims to compensate(i dont want to lower it) then at least 50 from the interior(probably more just the seats should weigh dam near that)... i did add some weight to the rear with the rear and LCAs... my car does not have wonder bar or any chassis braces either, if im over 3100 ill be pissed
Old Aug 8, 2011 | 10:28 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
1 lb bob
Old Aug 8, 2011 | 11:14 AM
who's Bob?
Old Aug 8, 2011 | 12:02 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
You may have to lower it anyway. Spring rates get funny when you take a lot of weight out.
Real weight of your car was around 3500# or so. It probably weighs around 3050# plus now more or less depending on gas, tools ect.
I really doubt it's less then 3000
BTW, there is nothing light about 4th gen wheels
Old Aug 8, 2011 | 05:24 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Originally Posted by FlippindaBird
who's Bob?
bob barker, mr price is right.
Old Aug 8, 2011 | 07:12 PM
so your saying the build sheet is off by 250lbs??
the 4th gen wheels are def lighter then the stock ones i had... seeing how i had a base firebird with 15s... pick one of those up then pick up the new ones... you easily can feel the difference, but i did not pick them for weight i traded my 3rdgens for them even up they look alot better and clear the LS1 brakes...
i wonder if 6cyl front springs would drop the front a little... i know they would help in a straight line launch
Old Nov 17, 2011 | 05:39 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Guess my weight.
Old Dec 1, 2011 | 01:40 PM
280 for both?
Old Dec 1, 2011 | 01:41 PM
the little girl is around 30lbs and the 5'6" man is around 250+
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
