Built a '88 Trans Am GTA from a pile of parts... part 2
Old Jun 19, 2010 | 02:29 PM
mustangslayer86's Avatar
Car: '88 GTA / '93 Z28
Engine: L98(350) / LT1 (350)
Transmission: 700R4 / 4L60E
If you wanna see part one go to the Tech/General Engine forum. This thread is all about pulling the body of this car together...
Couple general questions for you guys:
Where in the world do I find these upper hood louvers? Did all GTA Trans Ams have them? because I like the look without them as well.
The wrap around spoiler is still on the car. It doesn't look half bad, but for some reason the rear hatch doesn't align with the back of the car. I know I'm gonna be told to ditch the plastic one and get a fiberglass one, but I honestly can't afford that so does anyone know of a repair kit or something they sell that could help me fix it?
Any help is appreciated too... Lets just say after hearing this car run I'm definitely a proud GTA owner.
Old Jun 19, 2010 | 02:47 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Built a '88 Trans Am GTA from a pile of parts... part 2
The hood vents are the same as on trans-ams and GTA's, no different. Find a TA in a junkyard and get them if they are good shape. They have 4 bolts per vent for the front ones, and the rear ones snap in, I'd bring a plastic putty knife for those, cause you will mar the hell out of them if they are even slightly stubborn with metal.
How does the rear hatch not align? Does it stick out too far over the rear tail lights? Too far left/right? etc....
The rear hatch is actually clamped onto hatch glass and sealed with silicone. To adjust it you'd need to remove the silcone, the plastic interior piece, spoiler, and then you can get to all of the parts. Its a pain, I haven't fixed mine yet but thats what you have to do. Beware the whaletail bolts, they may snap off, then the wing is useless. Ask me how I know, my wing is constantly up now because one of them snapped off and now I can't tighten it down. Its time for a fiberglass spoiler.
T
Old Jun 19, 2010 | 02:54 PM
T
Alright I'll do that. Is there any place that sells them for cheap? I had an old YearOne Catalog from 3 years ago and they had them in there, but they told me they dont even sell them anymore.
Yeah it hangs too far back over the tail lights. Probably about 1/2 inch to an inch.
For the first part are you talking about how to adjust the spoiler or how to make the hatch line up again?
I probably won't replace the wrap around wing only because the guy I'm working with who is doing some of my body work with is positive he can fix it. One of the clips on the passengers side is broke though. I'm gonna have to see how he does this lol
Old Jun 19, 2010 | 03:40 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The hatch should be adjusted at the hatch hinges where they attach to the roof. The hinges can become 'bent' over time from the force of the hatch struts though and there may not be enough slack in the mount points to pull it back to alignment. In this case the hinges may need to be replaced or straightened.
When aligning it back up, release the struts to keep them from pushing the hatch back towards the rear of the car.
Old Jun 19, 2010 | 07:21 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I had to take my hatch completely apart and move the bottom plate forward, like mentioned in the 2nd post. That was a very aggravating job, and you'll need a helper.
Old Jun 19, 2010 | 08:05 PM
Yep, this is what I have to do to mine. The hatch glass itself is perfectly aligned. However the deck lid sticks out about 1/4" inch past where the 1/4 panels wrap around the tail lights. So it looks out of whack.
The only way to fix it is to redo the deck lid attachment, which is a pain. I also need to take it apart to reseal it so it doesn't leak. Fun, fun.
Old Jun 19, 2010 | 08:31 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I've got some vents if anyone needs 'em...
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
jharrison5
Aug 19, 2015 05:53 PM
gta power
Aug 13, 2015 06:15 AM
1nastygta
Aug 8, 2015 07:38 PM
