just bought two doors. ps and ds i have questions
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
i bought today two doors for 80 bucks not a bad deal i say so. they have good glass and solid. what im wondering is, they are from a 88' i think. will they bolt right up or is there some things i have to do. i can get pictures tomorrow.....can someone give some advice and some tips on putting them on and off. thanks youuuu
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: just bought two doors. ps and ds i have questions
They will bolt directly up. If they have the hinges still attached, use a jackstand under your door to support the door as your putting it on and off. Other than that, it's pretty simple stuff. Just getting the the back bolts are a pain, but can be done with a small ratched or a ratchet wrench if you have one. 13mm and 15mm are needed (I'm in the middle of doing mine right now, hahaha, so i can tell you right now what you need)
Good luck!
Good luck!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Should bolt right on - doors are all the same. You're gona need to make a holder (wood) and attach it to a jack (a tranny jack or motorcyle jack works well if you have).
My best suggestion - get new pins, bushings, rollers installed NOW - much easier on a door that's not on the car.
thanks man, im goign on vacay on thursday. so im goign to have to do it afterwards. just thought id get a thread going just in case someone has anything to say. instead of last minute. hha
thanks, where can i get the get new pins, bushings, rollers????
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
swweettt!!!!
86IROC112
Sep 7, 2015 01:37 PM
