LAMBO DOORS!!!!!
Old Jul 20, 2010 | 01:23 PM
sky-walker405's Avatar
Car: 1989 CAMARO RS
Engine: 5.0L v8 TBI
LAMBO DOORS!!!!!
does anyone know where i can find a bolt on lamo door kit that they would suggest for under $500...i see a few on the web for 350 but idk anyone who has used them....also im looking for a t-top headliner for under 75 ...help me out plz
Old Jul 20, 2010 | 01:49 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: LAMBO DOORS!!!!!
really?
If you truly like that look for a third gen. Make sure the company you buy it from has good hardware and can stand up to the weight of the third gen door, other than that it shouldn't matter where you get this kit from. Make sure you or the person installing it knows what they are doing and you should have no problems. It all comes down to the hardware and installer you will have to test fit and fit again to get things done right.
Old Jul 20, 2010 | 02:08 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Make sure you get a really strong assist cylinder - these doors can reach 100lbs easily. Also, take a picture of it - haven't seen many thirdgen lambo door conversions.
Old Jul 20, 2010 | 05:01 PM
UDAMON's Avatar
Car: Mazda Protege5
no such thing as a BOLT on for these cars. the door hinges are welded to the door and bolted to the body. therefor they REQUIRE weld on.
but if i were you. i would buy a bolt on kit and weld nuts to your door to make it able to bolt on. that way you still maintain adjustment which is critical, trust me.
Old Jul 20, 2010 | 09:53 PM
Car: 1989 CAMARO RS
Engine: 5.0L v8 TBI
i see the car on your thumb nail ...is that wat can where did you find yours?
Old Jul 20, 2010 | 09:55 PM
Car: 1989 CAMARO RS
Engine: 5.0L v8 TBI
i see the car in your thumb nail... is that wat you did and where and how much were yours?
Old Jul 21, 2010 | 01:47 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
he got them from ebay. heres a link to his thread https://www.thirdgen.org/forums/memb...mbo-doors.html
Old Jul 21, 2010 | 10:34 PM
Car: 1989 CAMARO RS
Engine: 5.0L v8 TBI
thanks ..i checked the link out and saw that he used two 150lb struts on each door..do you think a single 650lb strut on each door would work...and if you would check a couple of these links out for me and tell me do you think this would work i would appreciate it.
option 1
245.99 before shopping but has full spics. 3/8" cnc steel and min (650lb.) shocks
http://customlambodoors.com/chevrole...oor-kit-1.html
option 2
330.00 after shipping 3/8" steel no spics on shocks
http://exoticlambodoors.com/product_...roducts_id=394
option 3
299.99 but no spics. at all
://carlambodoors.com/8292-camarofirebirdtransam-bolton-lambo-door-p-240.html?osCsid=ec4729ff9fde92f59c2cd61d0f8ceebf
Old Jul 21, 2010 | 10:45 PM
87bluebird's Avatar
Transmission: t56
2nd and 3d links don't work. a 650 pound strut should be plenty strong enough.
Old Jul 21, 2010 | 11:19 PM
Car: 1989 CAMARO RS
Engine: 5.0L v8 TBI
thanks
Old Jul 21, 2010 | 11:26 PM
Car: 1989 CAMARO RS
Engine: 5.0L v8 TBI
oh ya and for all you nAA sayers who think these are only race cars and its a waist of money and time you could have just put that under your hood... y not look good in park after all you race with or doors closed
Old Jul 21, 2010 | 11:41 PM
87bluebird's Avatar
Transmission: t56
you can have the fastest thirdgen out there but if it looks like sh*t then it aint worth nothing.
Old Jul 22, 2010 | 02:03 AM
xxaviera55's Avatar
Scissor doors (also beetle-wing doors, jack-knife doors, switchblade doors, and Lamborghini doors) are automobile doors that rotate vertically at a fixed hinge at the front of the door, rather than outwardly as with a conventional door.
________________
Electronic Cigarette
E Cigarette
Old Jul 22, 2010 | 04:49 PM
UDAMON's Avatar
Car: Mazda Protege5
the 2 150 lb struts work OK.... they aren't too bad but it still takes effort. and just as much to close them. 650lbs might be easy to open but i cant imagine it would be much fun to close. although it might be different with one strut. i still need to play around and find a better setup for mine.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
