Removing and replacing door skins!
Old Jul 25, 2010 | 06:51 PM
'87Z28camaro's Avatar
Car: Soon t/b '84,'87 or '90camaro
Engine: 305,350, & 383 stroker
Transmission: 700R4 & T350
Axle/Gears: 373
Has anyone done this? How much work would that be? I know Eastwood sells door skin pliers but...
Old Jul 26, 2010 | 11:15 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Removing and replacing door skins!
Some yrs ago, HotRod or CarCraft did a skin change.
VERY vague memory, but I know it wasn't a 3rd gen F body.
Just a quick " Reader's Digest " dusty memory--
IIRC, it's got to do with getting the welds // spotwelds taken care of--
I don't recall exactly how but it seems there was a small grinder involved, and LOTS of patience. Maybe some spotwelds too , I don't know.
Care must be taken so as not to grind thru any door support structures.
RE-attaching // welding -- kinda slow because it's gotta be right so it looks straight, gaps are good, etc.
Mostly a time consuming process even if you know what you're doing.
I can't weld and have no patience, so the bodyshop likes to see me pull up!! LOL!!
I'm sure you'll get someone to direct you in detail, so good luck!!
Old Jul 26, 2010 | 09:47 PM
hardon85's Avatar
Does anyone sell new doorskins for 3rd gens? I have never seen any so I'm just wondering if they make any. If not why would you go this route? Wouldn't it be easier to just buy the whole used door since you would obviously need a used door to begin with.
Old Jul 27, 2010 | 06:41 PM
Axle/Gears: 373
Thanks for the info! I decided to repair the door I already have! It was actually better shape than I anticipated! Whoever did the bodywork, used way too much bondo! Earlier today, I discovered that whoever painted it, barely used any primer, so I'm able to peel strips of paint with a blade! Damn!!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
