Swing Lift Ground Effects
I am trying to buy a used 1992 camaro. I took it to a mechanic with the seller. The seller would not let the mechanic lift it up with a swing lift because it would crack the grounf effects. Is this true? also the brake light was on. They said that they replaced a brake line and that it will about 50 miles before it goes off. Is this also true?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Swing Lift Ground Effects
As for the brake light, that is complete BS. I just replaced 2 lines on my 92 Camaro last winter and the brake light never came on.
It REALLY sounds like this seller did some half-assed repairs and is trying to pawn the car off on the first sucker he can find. Unless you plan on going over the car with a fine-tooth comb and can fix any issues yourself I would turn around and walk away. ESPECIALLY if you're planning on using this as your DD/primary car.
Car: 87 GTA
The only way the lift would hurt the ground fx, is if there is a dumb lift operator. And apparently there was one, or he could have EASILY shown how they prevent that from happening.
The arms have different height arm ends, to reach up & to a good lifting point. Anywhere from 1" tall to 5" tall. All depends on which end the operator puts in. So if anything breaks, it is the operators fault, not the lifts fault.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its not problem lifting any car with a lift, with proper blocking, nothing will be damaged.
maybe the seller is trying to hide something? rotted floors? hack brake repair? i would defiantly look it over before buying it.
me and my buddy both have put our camaros on those lifts in boces with no problems with the ground effects, our only issue was the arm wouldent go under the exhaust without jacking the front of the car up
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
