Door manual to power windows
Old Aug 1, 2010 | 10:27 PM
audrasracing's Avatar
Car: 92 camaro RS
Engine: 406
Axle/Gears: 10 bolt 7.5
Hey, whats up to all my 92 camaro people out there. I have a 92 camaro and Ive had it since I was about 12. A drunk driver hit the passenger door. I have a spare door, but its off a 91 camaro but it has manual windows. how hard and can it be done to put the factory power window tracks in
Old Aug 1, 2010 | 10:31 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
Re: Door manual to power windows
do you have the original door with all the power window stuff in it. just swap all that into new door won't be easy but not super hard either.
Old Sep 17, 2010 | 11:42 PM
Camaro-454's Avatar
hello.......I looked at this thread with particular interest because I have to do the same thing. I own a 92 RS, 3.1L V6, that runs, drives, everything works, but I have no title for it so I can't register it. The good news is that I just found a 87 Iroc Body, that I can pick up for $260.00, and it's only missing one door, and has no motor or tranny. No problem. Since my RS is pretty much just a parts car without the title, I have everything I need right there.what's good is you are already ahead of the game because you have a door with all the necessary hardware inside the door. ( My RS has handle cranks too but I'm assuming that the Iroc will have electric wondows ). The main thing you will have to do is wiring the motor and making sure that you have good connections and a good ground. It may take some time but if you are patient and you pay close attention to what you are doing, ( and you have the perfect guide to follow just by looking at your other door while you work ), you shouldnlt have any real problems. Just pick a nice day to do the job ( if you don't have a garage to work out of ), and you should be just fine.Here is a website that will show you step by step and it is also illustrated with pics as well. I found this online after reading your post, so it's the same guide that I will be using as well. It's pretty good.http://www.p71interceptor.com/thirdgen/powerwindows/ Best wishes brother. You should be just fine. Camaro-454
Old Sep 18, 2010 | 11:17 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You pull the glass channel off of the power regulator and do the same for the other door, remove all the other tracks, undo 4 rivets on each regulator, pull the regulators out of the doors, and swap. You may want to replace the motor on the power regulator when you do this. Just watch out for that spring. It's a killer (and I have the scar to prove it).
Old Sep 20, 2010 | 03:59 PM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
Just got my self in the knee yesterday. Tie that thing up before you take the motor off.
Old Sep 20, 2010 | 07:46 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yep, got a half inch scar on my hand from where one of the screws kicked out of place when I reattached the motor... Cut clean through my skin and took almost a month to heal.
Old Sep 22, 2010 | 03:05 AM
Car: 87 formula
Engine: LG4
Those rivets are hard to drill out I wish i had a side grinder to do that job.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
