Can I spray rustoleum through an Hvlp to practice with?
Old Aug 17, 2010 | 04:19 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I picked up a hvlp paint gun from harbor freight today for 16 bucks I figured might as well use it to practice with it. I have an old mini van out back to practice with and I want to get the hang of how to spray the paint out through the gun. Could I use rustoleum and thin it out with mineral spirits? I'm going to be spraying my car with acrylic urethane when I get ready to paint it and don't want to make it look like crap being it's my first time doing it.
Old Aug 18, 2010 | 12:09 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Re: Can I spray rustoleum through an Hvlp to practice with?
i wouldn't. i learned by filling up the cup with water and spraying paper to figure out spray patterns, gun handling and overlap. you could substitute lacquer thinner instead of water. after i got the hang of it i used primer thinned correctly on a hood, then sent to paint, then to clear. basically the same way you would paint a car. reason i used a hood was it could be laid flat so there is less of a chance of runs or sags. but i had a $400 sata hvlp gun, and that was back in 2002.
Old Aug 19, 2010 | 05:09 AM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
you probably can. Here is a good article on what may be your gun and painting.
http://purplesagetradingpost.com/sum...Pspraygun.html
Old Aug 19, 2010 | 10:37 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
as long as the material is reduced correctly...you can spray anything you want through it
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
HoosierinWA
Oct 7, 2015 10:15 AM
TheExaminer
Sep 6, 2015 11:40 PM
