How to shave off 300lbs
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Okay, so I was using a 1/4 mile calculator and it was extremely accurate to what I was running in my quarter mile. So I fiddled around with the calculator and found out that if I can shave off 300 pounds I can reduce my time by almost a half a second. What could I do to reduce the weight of my car?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How to shave off 300lbs
depends on what you want to keep. Gut the entire car, remove all the ac, and under dash ducting, light weight suspension parts, lightweight wheels, ect ect ect ect. remove front sway bar, fiberglass hood.
going on a diet yourself can shave some weight too.
there is a thread is fab i think, "my midnight quest for 2800lbs", check it out
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
wow thats a good question lb is a lot of weight to take off.
you can look into swapping rims to start off. i don't know what your car looks like or what you have done to it but seats, bumper supports, speakers, power parts in the doors. there is alot of little things you can do but it will be hard.
also changing a-arms and cross member.
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
remove sway bars.. tear out all Pass seats, Remove the Carpet.. uninstall AC
purchase aluminum heads, Aluminum WP, purchase a 8 lbs starter
and as above fiber hood
K member is a possibility but mucho bucks
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I know on my car, interior carpet and rear seats was around 50-60 lbs and lightweight drag wheels was 70lbs off stock 16x8 iroc rims with ET streets...
Rims and interior can get you 150lbs I guess. After that, its gut sway bar up front, crash bars, any engine bay stuff you dont need, maybe manual steering vs power, etc.
Thats a lot of weight to cut tho. My thirdgen was in the 3300lb range without me and it had full interior but drag wheels at the time I believe. I was around 150-160 back then, and my raceweight was near 3450 with me in it. I"d have to check my old posts on when i weighed my car.
Okay, So there isn't to much I can do If I want to keep it a daily driver, I will look into the fiberglass hood though, and lighter rims.
Car: 86 Trans Am
Car: 89 Iroc-z
Transmission: TH400
hood is a good idea. Drops atleast 50-60lbs depending on what you get. The super light weight ones will do close to 70-80 I think. Stock steel is very heavy. But my harwood 4" cowl was also heavy for a fiberglass hood. I was dissappointed but I had to cut out alot of the under hood layer anyway to I saved some weight.
Car: 1986 Z-28
Transmission: 700-R4
You can also go through summit racing and get a set of fiberglass doors that also have the safety crossmember in them like the stock doors, only they way a whole lot less.
Car: 87 formula
Transmission: 700
i wasn't aware that summit had fiberglass doors i need to look into it for my self thanks lolol
Car: 1984 Berlinetta
Engine: 355
Transmission: 350
Axle/Gears: 4.30:1
I can shave off 150 real easy, let my nephew drive.
A friend of mine done those long bike rides, one of his friends was always buying some fancy "titanium" part to save a few ounces, my buddy said " I skipped breakfast"
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
