Some body rust questions
Old Aug 28, 2010 | 11:46 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Been a member for a while joined few years back to help a friend with a 92 camaro. Recently I bought a 84 trans am fairly good shape but few spots I want to take care of. Thanks NY and your salted roads.
Also is there an into section?
So here are some pictures any ideas?
There are a couple more spots but I have no pictures
Rear right hand side under the carpet
Door
Old Aug 29, 2010 | 06:43 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Some body rust questions
The door can probably just use a coat of paint. While that quarter, on the other hand, needs sheet metal work. Mine was worse, due to a FUBARed previous repair by the PO.
Where in NY are you?
Old Aug 29, 2010 | 08:18 PM
midias's Avatar
I am in Henrietta NY about 20 miles outside of leroy I often bring my motorcycles down that way for a nice country ride.
There are a few more spots I have found. Damn salt I will post more pictures soon but I need to get it on my friends lift this winter and clean everything with a wire brush then prime and undercoat.
Old Aug 29, 2010 | 08:36 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That quarter is already rusted through and is unsaveable below the body line... You can see daylight through a rust hole at the wheel well lip in the interior pic. You may be able to get away with cutting off the panel about an inch below the body line and flanging a new one in there. Either way, a wire wheel isn't going to save it down there.
You wouldn't believe mine was a Southern car when I got it, if you were to look at it now. At least they don't use sand around here, though.
Old Aug 29, 2010 | 08:48 PM
midias's Avatar
My fault I should have been more clear there are other places underneath that have surface rust but nothing serious I want to take care of those. For that spot I was thinking of hitting it with the wire wheel to clean the surface and see where I have good metal then welding in a new piece of sheet metal. I was just hoping there was a replacement piece I coudl buy. I have brand new 1/4 pannels in the garage that came with the car but nothing direct fit on that spot. I was also thinking if painting that under part black like a 2 tone all the way across the car like below. I think that would save me trouble matching paint
Old Aug 30, 2010 | 07:36 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Sadly, the only way to get a quarter patch panel is to cut it out of a junkyard car. We have 2 options... Skin or full panel (if you can find a full panel). For mine, since the sail was also damaged who knows how, I'm going to have to do a full panel. You should be able to get away with just the part under the body crease there above the marker light. You may have a little trouble getting the spare tire bracket loose from the bottom, though.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LittleFranks
Aug 20, 2015 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
