Headlight door won't open
Old Aug 31, 2010 | 04:48 PM
canadianT/A's Avatar
Car: 1991 Chevrolet Camaro Z28 C/V
Axle/Gears: 3:23 posi
Hello,
just picked up my 1990 GTA and the passenger headlight door won't open. I can hear the motor running but the door isn't even trying to open. I have the replacement gears but wondering how to change them.
Old Sep 3, 2010 | 10:01 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Headlight door won't open
Check out TDS, there you will find a kit to repair your headlight motors.
John
Old Sep 3, 2010 | 10:07 PM
The help is appreciated but the motor works fine, think the gears are gone and I have replacements. Just looking for step by step instructions
Old Sep 4, 2010 | 07:58 PM
okfoz's Avatar
Here is what I was unable to write last night which would have explained the problem.
The motors turn a shaft that turn three little rubber cylinders that spin and turn a larger gear. After time the little cylinders disintegrate. When you take apart the Headlight gearbox you will find it full of little rubber crumbs. you dump the crumbs and you install the delren pieces you buy from TDS... It should fix it, I think he also has gears.
Its a whole lot cheaper than buying new motors.
http://www.top-downsolutions.com/pro...products_id=87
its sounds exactly like what you need.
John
Old Sep 20, 2010 | 08:48 PM
I took it apart and changed the large gear but I haven't found where the 3 little cylinders go. They came with the large gear in the kit that I bought. After replacing the large gear the motor will turn properly but seems to run on for about 3 times as long as the driver's side motor. It will try and lift the headlight but just seems to slip.
I don't understand for the life of me why it runs on. Do the motors have a shut off when the arm on the linkage hits the stop and that kills the power? Somebody please help me out here. I am getting really close to just buying a new unit and putting it in but I have throwing money at my car for parts that don't make it faster/tighter.
Old Sep 20, 2010 | 10:16 PM
okfoz's Avatar
Its been a few years since I messed with one, I would contact Lon at TDS and he should be able to help you better.
I remember the little round things went in there, I actually made my own on a lathe, and 1.5 hours of messing around, but for the money it would have saved me to buy from Lon I wish I would have done just that... My Large gear was fine tho IIRC.
i want to think the little wheel things are internal... Now that I think about that comment, that really did not help.
Like I said, Contact lon. (626) 369-0400
John
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
