T-Tops Camaro/Firebird
Old Sep 3, 2010 | 12:35 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
anyone kno if the T-Tops are changeable between the firebird 3rd gen and the Camaro 3rd gen?...I was at a local junk yard and found T-tops on a firebird that look brand new with brand new weatherstripping,.. but I dont know if they are compatible...seems that the Tops on the Bird have a key lock on them that my camaro does not have but it has the handle latch like mine
Old Sep 3, 2010 | 02:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: T-Tops Camaro/Firebird
They are. As long as both are pins or both are hooks (C&C style).
Old Sep 3, 2010 | 05:42 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
My C&C tops had pins and no locks. There seem to be a variety of flavours offered by C&C. C&C tops will not fit a factory top openings and vise-versa.
One member has a set of C&C t-tops that can also pop up like a sunroof.
@Spacly-, Measure yours, measure the ones you got, you'll be able to answer your question.
Camaro and Firebird tops (factory) are dimensionally the same, though.
C&C tops are smaller (front to back).
Side note, we need a member with 'CogswellCogs' for a screen name now
Old Sep 3, 2010 | 07:40 PM
Car: 92 Camaro RS
Engine: 305 TBI
Damn, I cant measure mine..Im in NY visiting family where I found these...Im just ganna buy them anyway...if they dont fit I will sell them...they look too good
Old Sep 3, 2010 | 08:28 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The easiest way to tell is to look at the top of the windshield. If the width of the paint is the same between the T-top to the Windshield as the width of the "A-Pillar" then you have factory T-tops. However if the gap between the windshield and the T-tops is about twice the width of the A-pillar then you have C&C Tops.
From 1982-1983 and possibly early 1984 Factory T-tops used hooks, in 1984 they started using Pins, which lasted thru 1992. In 1985 IIRC locks were added to factory tops.
John
Old Sep 3, 2010 | 11:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If they are locking, factory T-tops will use the door key to lock/unlock.
C&Cs use a different key.
C&C cars were delivered as hardtops.So they have the hard top visors(wider)
Old Sep 3, 2010 | 11:39 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 has the glass factory tops have pins with locks that use the same key
as the doors and hatch.
Old Jan 1, 2011 | 07:45 AM
puma1552's Avatar
Anyone have pics from the outside of the car of this?
Or even better, comparison pics between factory and later model C&C tops?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
