any suggestions on this dent
Old Oct 15, 2010 | 05:46 PM
tylerf's Avatar
so a couple of months ago my car was in a hit and run. Left a pretty good size dent in the car. was seeing if anyone knew how i could pull this out, well make it look better.
That is the driver side, side panel. The door was pretty dented as well but managed to make it look better
Old Oct 15, 2010 | 06:01 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: any suggestions on this dent
http://www.classicindustries.com/fir...s/1668035.html
Old Oct 15, 2010 | 07:31 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
just a suggestion https://www.thirdgen.org/forums/body...ter-panel.html
Old Oct 15, 2010 | 07:57 PM
rich5's Avatar
Car: 91 camaro RS
dent... more like crushed. it would be alot of work to try and fix whats there but it really needs a new quarter or grafted section.
Old Oct 15, 2010 | 08:29 PM
tahoelt's Avatar
Car: 82 camaro berlinetta
Engine: carbed 305
^^^^ exactly! a new quarters only like 150 bucks and you could probably do it yourself, with a little welding skills and a bit of filler. or you could try to buff it out....
Old Oct 15, 2010 | 10:33 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
new door and a new quarter. lmfao to the buffer!! LOL
Old Oct 16, 2010 | 06:28 AM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
I cant believe you described that as a dent lol...
It needs to be replaced. Although i've seen maaco work miracles with this new product called "bondo"
Old Oct 16, 2010 | 07:13 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
It's not BONDO, it's lightweight aerodynamic body enhancer.
And yes you need a 1/4 panel and at least a door skin. IMO
Old Oct 19, 2010 | 01:23 AM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Your best bet would be a new 1/4. The time and effort it would take to fix that, along with reforming the body lines, is waaaay more than it's worth. and that's more than just a dent
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
