Hatch pull down delete
Old Oct 17, 2010 | 03:29 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Hi
Today I discovered that my hatch motor was not working fine any more and for sure will prefer a normal lock instead of all the heavy lock with all electric and motor!
Can any one in here have one for sale? and also wish to seea pic of it even if you dont have one for sale so I can see how it is!
Old Oct 18, 2010 | 11:43 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Hatch pull down delete
I just shut mine, let the hatch pull shut, and disconnected the wire. Worked like a normal hatch after that. And it doesn't weigh enough for your engine to ever know it's there.
Old Oct 18, 2010 | 12:10 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
i took all the wiring and gears out, and welded the latch down. however it's as low as it can be and still grab the striker on the hatch, but not all the way down and you can hear the hatch rattle over bumps.
Old Oct 18, 2010 | 02:36 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Ok will se it tomorrow! any one in here knows if any modification has to be made to put an older lock w/o thepull own hatch?
Old Oct 22, 2010 | 05:34 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Today with some help from a friend I removed the pin of the shaft that goes up and down with the latch entered in the trunk and positioned the taolgate where it locks and positioned the latch in the rail with a felt pen and screwed the rail with 8mm x 50 bolt and a locknut and its a solid thing!
Removed the elecctrical socket so now its manual and it closes also without any need of all that electrical staff
Old Oct 22, 2010 | 11:36 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
fyi, the older non-motorized ones, at least in the 84 Trans Am I was looking at, has the assembly welded to the car. I went to the yard thinking that they unbolted like the motorized ones but they don't.
I lined up mine and just drilled two holes and bolted it in place.
Vintageracer
Jan 10, 2020 05:33 PM
zayne0
Aug 24, 2015 07:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
madsv1000
Aug 20, 2015 06:45 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
