intake
Old Nov 5, 2010 | 11:26 AM
jmcclelland2004's Avatar
Car: 89' Camaro RS
Engine: 305 TBI
Transmission: 4Spd auto
Axle/Gears: stock
intake
If anyone has any ideas i will take them. My goal is to get cold air to enter through the front of the car into my air intake as opposed to the way it does now. I have a 305TBI engine and the intake is composed of a couple of plastic tubes that bassically mount to the top front of the engine bay. I notice when i close the hood that there isnt much air getting through here and it is probably sucking in hotter less dense air. I am thinking if i can get the intake maybe piped down under the car so that the intake draws in colder more dense air i can inprove power and economy. Any ideas on if this will be good or is it going to give to much air and cause my engine to run way lean
Old Nov 5, 2010 | 11:28 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: intake
Do some searches on the engine forum. Many say your setup is very good as is.
Old Nov 5, 2010 | 11:30 AM
Car: 89' Camaro RS
Engine: 305 TBI
Axle/Gears: stock
Re: intake
okay i will take a look alot of people say the single set up is garbage and the dual set up is way better ( sorry when i said couple i meant total peices not air intakes) the setup is with the one intake to the drivers side of the engine bay but thanks for the advice
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
