How to fix broken tabs on ground efx??
Old Nov 7, 2010 | 11:16 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
A couple of the tabs that attach the ground efx to the car are broken. Is there a fix or a way to rig them so they will attach? Next year I may put efx from a newer one on, the ones with the holes, but for now I would like to fix:
Old Nov 8, 2010 | 07:55 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: How to fix broken tabs on ground efx??
it depends where they are . if unseen i have used pop-rivets with a small piece of metal & 2 part epoxy . if mounting studs are pulled out of material , clean stud , rinse/clean both areas with acetone/laq. thinner . lite coat of 2 part epoxy on both parts secure with zip ties or clamps . let cure at least 24 hrs. or more . just a few things that have worked for me . i prefer epoxy resin over polyester resin when doing fiberglass repairs . too easy to mix polyester too hot & brittle . just really think things out before hand & ask lots of questions . cheap throw away glue brushes , acetone/ laq.thinner , 2 part epoxy , & pop-rivets have been good to me . good luck .
Old Nov 8, 2010 | 07:25 PM
Mathius's Avatar
A good epoxy or that plastic weld solution can sometimes work well. The proper way to fix it would be with an actual plastic welder. I tried it in the past without much luck. I've been welding metal for years, but my plastic weld dropped right out when it cooled.
Mathius
Old Nov 8, 2010 | 07:37 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I don't have a plastic welder but I will try epoxy. Can holes be drilled through for the bolts without the " new" tabs breaking?
Old Nov 9, 2010 | 12:21 AM
popballz's Avatar
Car: 89 firebird
In my experience, Epoxy works well for a few years then starts falling off. I had this awesome guy help me plastic weld a few of mine, two years later, they are still perfect.(I also swapped cars and they are still one piece!)
I am not sure what you mean by "new" unless you were trying to reform the tabs out of epoxy...you can drill holes threw epoxy..?
I would do what "UNCLE TOM" recommended, epoxy with a reinforcement of metal!
Frozer!!!
Jan 19, 2024 04:55 PM
dibella989
Sep 1, 2015 04:12 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
theshackle
Aug 31, 2015 10:47 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
