tire sizes?
Old Nov 20, 2010 | 05:28 PM
docpnutbutr's Avatar
Car: 87 Z-28, 89 GTA, 79 WS-6,
Engine: 87- 305 TPI, 335 stroker, 403 Olds.
Transmission: 700r4,700r4, and th400
Axle/Gears: mostly stock
tire sizes?
Anyone ever run 295/50 16's on IROC or GTA 16x8 wheels? Wondering if there was any rubbing against the shock or fender lips. I run 255/50's on GTA wheels now, but they just don't look big enough to fill the wheel wells. Any ideas?
Old Nov 20, 2010 | 09:26 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: tire sizes?
A 295/50r16 is too tall to fit on your car. For something that wide you'd have to go with a 45 or 40 series. probably a little too wide for a 8" wheel to.
Old Nov 21, 2010 | 01:18 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: tire sizes?
Try 1010tires on the web. They have a tire calculator that compares tire sizes and what the recommended wheel size is. I don't think an 8 inch wheel is nearly big enough for a 295.
Old Nov 21, 2010 | 02:02 AM
Stephen's Avatar
Car: 87 GTA
Re: tire sizes?
A would have shown you many people (i'm one) who has or currently does run the BFG 295/50s on their stock 16x8 wheels. And with zero mods to anything to run them.
Here is just 1 thread of many. A 8" wheel is actually within manufacturer's specs for the tire. The minimum spec, but still within spec.
https://www.thirdgen.org/forums/whee...5-50-16-a.html
Old Nov 26, 2010 | 02:10 PM
stackofire's Avatar
Car: 1991 Camaro Z/28 305
Re: tire sizes?
I can only confirm that you can fit BFG 275/60 15" on the back with no modifications but they will rub a bit on the wheel arch on the bumps.
Here's the pic:
21092010255.jpg?t=1290802285
Old Nov 29, 2010 | 05:53 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: tire sizes?
Drop the car an inch or so.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
