pictures of 295-50-16?
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
I'm wanting to buy a set of the bfgoodrich 295-50-16's for my car but want to see some pic's of people with them on there cars to see how they look. do they stick out at all?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: pictures of 295-50-16?
This is a old photo of a 295/50r15 on a 8 in. rear wheel. Obviously not a 16in. but will give you some idea as to what they look like.Tire width and your back spacing are what is going to determine what your end result will be. That being said, I made a mistake with the BS on my rear wheels so they run slightly further out than I would like with that tire. Something I will remedy when money is not so tight.
Edit = Went to a smaller tire 255/60r15s rear,(photo below)and think it looks better/cleaner than the rear balloon tires I have in the above photos.
Car: 87 GTA
What is the bs on your wheels? Here is my old car with stock wheels & the BFG 295/50R16s:
Bad pic, but.....:
This one is a bit better, as far as showing how the tire fits:
Bad pic, but.....:
Car: 87 GTA
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 87 GTA
Well.....Offset is only a measurement <based on> from tire seat to tire seat. Backspacing is measured from the lip to the hub back.
If you go measure a wheel, you will find it does not physically equal its advertised width. So if you go measure a 0 offset wheel, you will find that it does not equal half of its advertised width. My 17" x 9" ROH Snypers with 0 offset physically measure 5" backspacing.
Check out Skultes FAQ about measuring backspacing here, so you can see its not just me.....
http://www.skulte.com/adapterfaq.html
Te misunderstanding of backspacing & offset in relation to each other, is what caused me serious frustration in trying to explain to others when I was trying to fit my 11s. When I stopped trying to explain it to others & just did what I knew was right, it all went as smooth as glass!
Car: 86 Trans Am
Well.....Offset is only a measurement from tire seat to tire seat. Backspacing is measured from the lip to the hub back.
Offset is the distance from the centerline of the wheel to the mounting surface, positive or negative. Personally i like BS better, offset is just more worki seem to remember my old stock 15x7's having 4.25 " of backspacing, fwiw.
Car: 86 Trans Am
Car: 87 GTA
Never mind.....I'm not going through this again. It wasted too much of my time before & I'm NOT doing it again.
Car: 87 GTA
Frustration made me type too fast & not be clear in my words.
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
sorry to threadjack but im going to ask a simple question how wide can we tuck in our wheel well without sticking out a ridiculous amount
Car: 87 GTA
How much are you willing to cut out? I have 315s (i'll be putting 335s on these 11" wheels come tire replacement time) on 11" wheels & could easily go to 12"s and probably 355 width (or more), & still be under the fenders easily. And I didn't do any major cutting of metal. Some cutting, yes. But nothing real major.
Car: 86 z28
Engine: 305ish
me + cutting metal isnt the safest thing but 315's is plenty wide enough for me i wont ever use that much tire ill prolly go with 275's - 285's on the rear and if they dont fit ill find sombody with more car sense then me and then ill start cutting things off
and i still wont use that much tire
Car: 87 GTA
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The only way that stock 15x7 rims measure 4.25" BS is if you measure it the correct way:
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Car: 87 GTA
I've never seen anyone measure a wheel from inside the tire bead seat instead of measuring on it. I know all the measurements I've taken or seen taken been taken on top of the bead & resulted in their advertised bs. Measuring that way would have resulted in measurements that contradicted what the manufacturer said they were.
Car: 86 z28
Engine: 305ish
You got 16" wheels? The BFG 295/50R16s will fit a stock 16" x 8" wheel just fine & fit the wheel well just fine too, wit zero mods. I know because I've done it.
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
ok so i see you guys doing them with the bfs, now i have the mickey dr2s and i have al kinds of issues with fitment, i cant get them to stop rubbing the fender with the stock springs in, i had to bash in the inner fender to get them not to rub, now i dont know if it has anything to do with the fact i have gta rims, i auctually have the moog helper springs and 1 inch spacers but theres so much gap they look so stupid, im gonna grab som pictures tomorrow after work so you can see what i mean and possibly help me out
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Car: 87 GTA
It is in the thread title & only 1 manufacturer makes a street tire in that size.....
BFG 295/50R16s @ Tirerack.com
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I think that looks silly.
Maybe due from the small front tire, but just doesnt look right to me.
Car: 85 Z28
Engine: ZZ-3,Mini-Ram, Holley EFI
Transmission: 700-R4
Axle/Gears: Hawks 8.8
On Probation
Engine: several
Transmission: none
Axle/Gears: none
A few weeks ago there was a guy at the car show who had these 295/50R16 Radial T/As on the back of his '84 Corvette Z51. These look great on a 9.5"-wide wheel like his.
Engine: 231
Transmission: 2004R
Axle/Gears: 12 Bolt with 3.42s
Did you guys notice any deference during hard cornering?
i have a set of OE Irocs on my 68 Chevelle Which we all know its not a great handling car. i wonder if tires this tall and Bubbly would hurt the lack of handling even more?
Car: 87 GTA
Car: 85 Z28
Mine feel the same as my 255/50-16 BFG dr's did.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i know im reviving an old thread but i want to put these on my rear crosslace wheels... what do you guys think...
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Good luck finding a pair, they've been discontinued, due to slow sales, due to high price, due to slow sales, it's BFG's favorite game, they want immediate RoI, thus lose the entire investment. I guess they really just like to tease us then write off the loss.
i know i just saw.. smh... they were on tire rack like last year and i almost bought them but a member on here said that they performed like poop.... well it looks like im restricted to 255 thens....
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
This is the truth. I forget the size, but 2 of my buddy's are trying to get a BFG TA and I guess they only make them once or twice a year in a limited run. The one guys 34 Chevy has the rear fender built for house that one tire size so anything else is just not spot on.
Linson
Sep 21, 2015 01:08 PM
Street Lethal
Sep 7, 2015 01:09 PM
