window loose
Old Dec 11, 2010 | 08:35 AM
miner's Avatar
Car: 88 Iroc-Z
Transmission: T-56 Manual
Axle/Gears: 3.23 10 bolt
window loose
Hi my driver window rocks from side to side a lot. It moves out of the black triangle guide that sticks above the door when you close it. I replaced the regulator which solved the back and forth rocking problem from before but didnt help with tue side to side at all. It looks like there is a guide rail at the front of the door that connects to the black triangle. The window is in it but there is nothibg holding it in place when i hold the window up against the rail it doesnt rock at all so im pretty sure it is supposed to keep it in place. There is a white plastic peice attached to the window right next to the rail that is exatly the sane asthe peice.es that hold the window to the rails on tje rest of the door. This one isnt attached to anything. I was wondering if there was a peice missing or what exactly is wrong.
Old Dec 11, 2010 | 11:06 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: window loose
I think I understand what you're talking about. With the door trim panel off, there is two guides on the top of the door. Loosen the 10 mm bolts and slide the brackets toward the outside of the door. Not too much as it will cause the window to bind and not roll up and easily. You may want also to check other parts while you're in there. There should be blocks on the outer window moulding also to help keep the window from being loose. I've seen them fall off, look in the bottom of the door. May find something else. There is a tech article on the home page that'll help also.
Old Dec 11, 2010 | 11:18 AM
miner's Avatar
Car: 88 Iroc-Z
Re: window loose
Here's pictures
The first one is the rail the window is loose in
the second and third show how much the window moves.
Is there a bushing or a roller or something that goes there that's missing?
I've tried messing with all the adjustments and replaced the regulator, I really dont know whats wrong the passenger side is perfect.
Attached Thumbnails window loose-2010-12-11_08.21.47.jpg   window loose-2010-12-11_08.23.08.jpg   window loose-2010-12-11_08.23.16.jpg
Old Dec 11, 2010 | 11:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: window loose
Lower diagram is 83-84, but yours should be similar.
The channel in the guide below the triangle seal should be loose (normal).
1. this adjust the trianlge bk/forth & in/out.
2. Front stop (top)
3&11. adjust angle on tri seal.
6.Rr Stop (top)
7. Glass bk/forth adjust.
8.Glass pivot in/out (top)
9.Pivots window up/down fr to bk (top)
There is also a sticky that may be of help.
Old Dec 18, 2010 | 09:24 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: window loose
Any luck?
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
