Foglights/ headlight lenses
Old Dec 21, 2010 | 03:38 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Ok, well my foglights flat out dont work, I BELIVE they did before the car sat but they just dont currently, But anyow on both sides I belive the wires were torn apart, so what do I need to do to get those back together?
Also it'll probay be a good idea to get some new bulbs to, Im just lookin into buying an bulb that is an very light blue, what color K temp do I need for an light light blue?
Also what part # would it be for the glass lense's for the headlights/high beams? I just need two for the high beams as mine are cracked and duller then the others.
Thanks all.
Old Dec 21, 2010 | 03:49 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: Foglights/ headlight lenses
SO we meet again...
My fog-lights don't work either. P.O said they worked and then one day they just stopped. Apparently he tried to mess with the wires and after not being able to fix it he unplugged/ripped it all out. So I'm in same position it seems. Probably why my fuel gauge isn't working either, he probably pulled more wires than he should've. I don't even wanna touch em unless i know what i'm doing. Wiring and electricity aren't my friends you could say rofl
Old Dec 21, 2010 | 04:00 AM
Engine: 305TPI
LOL so it is....
And yah, I dont unstand the smallest bit of wiring, electricity, etc. I didnt find out tell like a yr ago that electricity transfers thru metals haha.
Old Dec 21, 2010 | 08:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
wiring can be daunting, but with the right tools and diagrams, its gets much easier to figure out. there's a ton of good factory wiring diagrams here
as for the lighting you need, your high beams are H4651 halogen "capsules". these cars used sealed assemblies, so you'll need to replace the lens/reflector/light all as one unit. Pretty readily available from any of your local part stores
Old Dec 21, 2010 | 04:51 PM
Slash's Avatar
I'll be completely honest i look at the wiring diagrams and my mind goes blank "uhhhhhhhhhh" lol
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
