T Tops
Old Dec 30, 2010 | 12:27 AM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
T Tops
my 90 RS with T tops is original from cali and its got some major rust in the t tops i found a car no motor or trans for 125 bucks with pristine t top roof i bought the car and am now wondering what the best way to swap the t top roofs would be? factory spot welds or just cut it at the bottom or top of the a and b pillers thanks
Old Dec 30, 2010 | 06:42 AM
white_formula's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 ltr 350 carb
Re: T Tops
I'm not sure on the t tops style roof but I do knp u only want to replace the bad metal and save the good
Old Dec 30, 2010 | 12:39 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: T Tops
This has been covered again and again. Have you done a search? It is ALOT of work and if you dont brace the car correctly before cutting you may end up with alot of problems.
Here is the link to someone who did the work and documented the results...
https://www.thirdgen.org/forums/body...-top-roof.html
Old Dec 30, 2010 | 05:12 PM
Car: 1990 camaro RS
Engine: 305 TBI
Re: T Tops
that was hard top to t top i wasnt sure if there was suports in the a and b pillers and thats why he did the swap like that i wanna do t top to t top
Old Dec 30, 2010 | 05:17 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Re: T Tops
Its the exact same proceedure with no additional supports....Going from hardtop to T-Top is the same as totally cutting off a T-Top and replacing it with another T-Top roof.
Old Dec 30, 2010 | 05:36 PM
Car: 1990 camaro RS
Engine: 305 TBI
Re: T Tops
ok thanks
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
