Sagging door after TDS Kit
Old Jan 13, 2011 | 01:30 AM
wnmetal's Avatar
Car: 1991 Firebird GTA
I finally got tired of having to slam my door every time i wanted to close it. Kinda makes it look like i'm always pissed at my car or something, so i got the greasable hinges from top down solutions which is really andyz28 hinge kit for some reason a few bucks cheaper. Anyways i installed the kit by my door is still off by a quarter of an inch, I dont have any alignment tools but my idea right now is loosen the adjustable bolts on the hinge just a slight bit and use a jack to lift the door then tighten bolts again, anyone done this before? tips? ideas?
Old Jan 13, 2011 | 10:04 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: Sagging door after TDS Kit
Hate to hear that as I just got my TDS hinge kit in yesterday....
Please follow up with what you find out! I would call TDS and talk to them. They were very helpful with me on the phone!
Old Jan 13, 2011 | 10:15 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Did you mark the door hinges before you took the door off? If not, you may just be out of alignment. We rebuilt a door hinge off of 91 Z28 about 6 weeks ago and marked the hinges before removing and with the new hinge kit in, it was almost perfect.
Old Jan 13, 2011 | 11:10 AM
wnmetal's Avatar
haha dont get me wrong man its a solid kit, i move the door and the whole car moves with it, its just not aligned which is where im wondering if my idea would fix that
Old Jan 13, 2011 | 11:12 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Yes that should fix it. Try not to loosen both hinges at the same time as the door may move down on you and rub the rocker molding.
Old Jan 13, 2011 | 11:14 AM
wnmetal's Avatar
no that was one of our biggest mistakes , i'll get workin on it today and get post what happens tonight
Old Jan 13, 2011 | 11:25 AM
wnmetal's Avatar
oh ok thanks for tip, i was gonna loosen both sides haha
Old Jan 13, 2011 | 03:11 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
the using a jack method is actually a common process lol you hit the nail on the head
loosen one hinge jack it up just a little tighten and keep going with that same process till its right some guys have quoted that they have to actually go with two bolts instead of three cause it sagged that much
Old Jan 14, 2011 | 12:35 PM
wnmetal's Avatar
haha yeah well i loosened bolts and jacked it up but just couldnt get it to stay up, i loosened just top bolts and bottem were tight, jacked it, it went up, but then went right back down. took it to the body shop and they did the rest of the work for me. door closes with the slightest effort and one thing it also opens with the slightest effort, its amazing, i was gonna use that 100 to buy tickets to see ozzy again but im definitely happy with my purchase
Old Jan 14, 2011 | 01:31 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
GREAT to hear. I am dropping mine off at the bodyshop tomorrow!
86IROC112
Apr 9, 2016 10:20 PM
BHR
Sep 3, 2015 07:51 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
