Door Rattle
Old Jan 17, 2011 | 11:21 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Door Rattle
i read through the sticky and i dont thing anything in it is my problem, i have a 90 t top RS and whenever i hit any small bump or bigger the passanger door sounds like its gonna rattle and fall off and fly open, it opens and closes just fine and it doesnt sag i dont get why only the passenger door does it ive got pwr door locks, manual windows, how do i stop or quite the noise
Old Jan 17, 2011 | 11:51 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: Door Rattle
have you taken the panel off and inspected it?
Rods in it could be making noise, I think on the other thread i read about the window bumper things deteriorating and the window slapping against the metal every now and then making noise.
Best to just pop off that door panel and shake things around and see what could make noise, and wrap them in something, or place something by them.
I knew someone who put electric tape all in the door in different areas, I cant say how well it'll hold up... But it worked for him.
Old Jan 17, 2011 | 11:52 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: Door Rattle
Best way is just dive in and pull the inside of the door off and see what it looks like in the inside of the door. Could be that something broke and the broken piece is moving around or it could be that your glass is not being held in place. This video will help you if you need to get an idea on how to remove the internal door panel. Basically take it off and shack the door a little and see if you can't track it down.
Old Jan 17, 2011 | 11:54 PM
Car: 1990 camaro RS
Engine: 305 TBI
Re: Door Rattle
thanks, im thinking maybe the window bumb may have broke but with the noise it makes im 99% sure its not just the rods, ive driven my bros 4th gen with the door panels off and the rods moved a little, they didnt make nearly as much noise as this, anyone else got any ideas cuz i really wanna get this fixed, thanks for you input faded ill let you know if it works
Old Jan 17, 2011 | 11:56 PM
Car: 1990 camaro RS
Engine: 305 TBI
Re: Door Rattle
thanks for the link RS and yea ima try shaking it i hope i can find it
Old Jan 18, 2011 | 01:57 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Door Rattle
My 91 T-top RS doors would make noise over bumps in the road. But it was clear to my ear that the noise was not inside the door but the door itself.
Strikers and latches were not worn and I replace the pins and bushings with AndyZ28's kit. What was not replaced at the time was the worn out door seals.
With the weight of those doors and the flex of a T-top body it needs the seals to be in good condition to keep them snug. I could hold a little pressure on the door when on a bumpy road and they would not make a sound.
New seals and the noise was all gone.
Old Mar 26, 2017 | 07:33 AM
Oldpackrat's Avatar
Re: Door Rattle
I have been trying to stop all rattles in my doors (82 Camaro) and one item
you might check is the inside door handle, its pop riveted on, mine would
wiggle up and down against the inside of the door. The handle is slid on to
the door then the pop rivet is put on to secure it. I took the door handle off
and tightened the clamp portion that slides on to the door then pop riveted it
back on and now it doesn't wiggle against the door. I suspect that over time
the clamp portion of the inside door handle opens from pulling on the handle.
Just a thought!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
