WEATHER STRIPPING QUESTION
Old Feb 2, 2011 | 01:52 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have an '84 Z28. In both doors there is a vertical channel (towards the front of the car) that guides the window up and down. The outside is metal and there is a rubber insert to cushion it against the glass. The rubber is dryrotted and I would like to replace it.
2 questions.....
1. What is that called? Is it weather stripping?
2. Where can I get some or is there a good replacement I can use instead?
Old Feb 2, 2011 | 05:19 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: WEATHER STRIPPING QUESTION
I have seen that in either the Classic industries or Year One catalogs or both. I loaned mine to my brother so I cannot look it up. Maybe try 1Aauto.com as well.
I don't even recall what they named it but you should be able to find it in the body/weather stripping sections.
Old Feb 3, 2011 | 12:06 PM
Car: 1984 Z28 T-TOP
Not in A1 Auto or Classic Industries. I'll check Year One. Mabye it isn't under weather stripping. It acts more as a window guide.
Old Feb 3, 2011 | 12:15 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Called a Triangle Seal. Buy from 1aauto. I have had great things to say about them! Ill get a link..
http://www.1aauto.com/1A/Weatherstri...SK00182/260239
There you go man!
Old Feb 3, 2011 | 01:36 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
thanks for the mention! if you guys need help, you know where to find me
Old Feb 3, 2011 | 02:08 PM
Car: 1984 Z28 T-TOP
It is not the triangle seal. This is INSIDE the door. You must remove the door panel to even see it. The triangle seal is above the piece I am refering to.
Old Feb 3, 2011 | 02:18 PM
Starting checking around at 1a and hawks in the door assembly categories. You'll most likely find it there
Old Feb 3, 2011 | 02:26 PM
Car: 1984 Z28 T-TOP
Hey Dan, if you guys have it, I would love to buy it. But I couldn't find it on your site. Mabye I am looking for it in the wrong section or wrong name.
Old Feb 3, 2011 | 02:32 PM
Car: 1984 Z28 T-TOP
Year One:#1 All 1982, some 1983-1984 models with separate glass run channel door glass filler panel, driver side, GM.
#2 1982-1992 door glass rubber filler seal, aftermarket.
These both sound like they could be it, but no pics.
Old Feb 3, 2011 | 04:07 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
The nice thing about Classic industries is you can see the part in their printed catalog, but, when you use their part number, or even search their site, its says "Not Found"!
They like to tease or something!
Old Feb 3, 2011 | 04:08 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I think the OP needs help
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
redmaroz
Aug 16, 2015 11:40 PM
