High Beams
Old Feb 8, 2011 | 04:34 PM
StephenS's Avatar
Car: 1991 Z28 Camaro Convertible
Engine: 1988 305 TPI
High Beams
I got a quick question about my high beams. Basically they don't work. All my other lights (except trunk light) work. When i pull the cluster stick thing for most usual working things on the car (turn signal, windshield wipers, cruise etc., nothing happens. If i'm not mistaken it's supposed to click for the lights to stay on. Pull a little to flash them, pull all the way and they will click on. The stick won't even click. I'm not sure how to check the voltage but i do have a multimeter. I'm hoping I won't have to buy a new cluster stick.
So i'm asking how to check the voltage of the high beams to see if they even still work
Old Feb 8, 2011 | 04:43 PM
AmorgetRS's Avatar
Re: High Beams
I am guessing that you need to adjust the high beam switch. It's located near the base of the steering column. All the stick does is push a metal rod that hits the switch. Easiest way is to take off the lower dash plastics and move the high/low beam stick and watch for a metal rod moving and follow that to the switch. It screws to the column and has slotted holes for the screws, so you can just loosen and adjust. If no metal rod is moving something is messed up higher.
Old Feb 9, 2011 | 02:23 PM
StephenS's Avatar
Re: High Beams
I couldn't find that metal rod you were talking about. What do you think I should do now?
Old Feb 9, 2011 | 03:25 PM
AmorgetRS's Avatar
Re: High Beams
http://www.oreillyauto.com/site/c/de...1970&ppt=C0039
Look for this switch on the steering column.
Old Feb 9, 2011 | 04:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: High Beams
You should see the rod moving up/down the steering column with the bottom kick panel off, a flashlight in your mouth, and a major cramp in your neck - move the high beam lever while looking up under there. There's two tiny (7mm or 8mm) screws that hold it in place - lossen those just a bit, adjust the switch upwards. Make sure if you have tilt wheel the wheel is set where you normally drive. Retighten screws.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
