broke part under front left fender idk wat to call it
Old Feb 10, 2011 | 07:51 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
so im missing this
idk wat to call it like io said in my previous p;ost imma noob
plz help for wat it is called where to find
broke it driving to far off my dads ramp regret it every time i look at it
Old Feb 10, 2011 | 08:24 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: broke part under front left fender idk wat to call it
ground effect and you will need to look around for em
Old Feb 10, 2011 | 08:38 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Doubly true since that is a 91/92 GFX.
Junkyards and craigslist are your best bet. Look for guys parting 91, or 92 birds. Don't bother holding out one that matches your paint. Just get it sprayed.
Old Feb 10, 2011 | 08:54 PM
dabird07's Avatar
Car: 92 firebird
thanks!! its so ugly it bugs me!!
Old Feb 10, 2011 | 10:42 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
should think about getting the bumper repainted. paints wrinkling off and just a matter of time before it flakes off. Make sure they put the flex additive in the paint when they spray it
Old Feb 11, 2011 | 06:18 PM
dabird07's Avatar
Car: 92 firebird
i know this is true my friends going to do it for free (i gotta buy paint so not free) idk wat color to paint though black and white stripes white and black stripes
silver and black stripes or black and yellow stripes
bout to draw up some pics or customize a camero on a video game :P
with som e 18" irocs chrome low profile. . .
Old Feb 12, 2011 | 12:15 PM
Car: 87 TA clone
im more of a subtle kind of guy... I thought about doing a ghost stripe. Perhaps a dark charcol strip on black car would be nice. Or even a flat black stripe on a black shinny car would be sick. I cant stand yellow on anything, a suttle stripe to me looks better than a bright stripe. I also like painted wheels vs chrome. painted looks better as chrome has to be perfectly cleaned and takes awhile to do each wheel lol, painted also seems to last longer. Big chromes look like big DUBBS to me and thats too much flash to be focusing on one part.
too each his own tho
Old Feb 12, 2011 | 01:04 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Hawks actually has these for sale as reproduction pieces. Kind of expensive, though.
Old Feb 13, 2011 | 09:38 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
actually, they are cheaper than what a perfect, or even good, original would usually sell for.
not sure on the actual fitment though. Not sure if anybody has them yet,
Old Feb 13, 2011 | 12:15 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Wasn't there a member here that was fabbing them at his metal shop and gonna
sell them???????????
Anyone remember?
Old Feb 13, 2011 | 10:45 PM
dabird07's Avatar
Car: 92 firebird
went to pull a part earlier today and know luck!! found a 91 bird walked up to it and saw it had the piece on the passanger side so went to drivers side and saw nothing so evidentally alot of peeps break this peice O.o
very disapointing .. .. .. any one know a site???
and decide to paint it black and white stripes although the flat black stripes does sound like a good idea
Old Feb 14, 2011 | 12:53 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Its called a fender ground effect and Hawk has them used for $125 bucks:
http://www.hawksthirdgenparts.com/fi...ectlhorrh.aspx
Did you check thirdgenranch.com?
Old Feb 14, 2011 | 01:17 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
Should have taken the opposite side from the yard you went to, I've found many parts yards are ignorant to the value of parts like these, could have gotten it cheap and sold it for the cash to buy the one you need, or just keep it around incase!
Old Feb 14, 2011 | 03:48 PM
rich5's Avatar
Car: 91 camaro RS
if you paint it black you will see every flaw, in paint and color. just a thought.
Old Feb 14, 2011 | 11:36 PM
dabird07's Avatar
Car: 92 firebird
didnt think about that cause my car does have flaws a lil dent int the door and rear panel scratches but hopefull i can fix all that
and them doors are heavy!!!
so please post opinion
will taking out the power window motor in each door make it lighter?
Old Feb 15, 2011 | 12:02 AM
Stephen's Avatar
Car: 87 GTA
Anyone remember?
That was FYRCHKN. His turned out good, but not sure if he ever was able to make & sell more. Had some big changes in his life. He's still around, just not nearly as active on the 'net as he used to be.
Old Feb 15, 2011 | 12:19 AM
Car: 87 TA clone
doors are stupid heavy... a pair of fiberglass doors will set u back about 700$... but they weigh nothing barely... also u need to use lexan glass. The stock doors are heavy cuz GM used that as supports for the cars subframe. Youll notice in the doors (if u peak inside) has a LONG HEAVY support bar in the middle of the door (outside) to help with side impacts and protect the passengers. You can remove these by cutting the door apart to help shave some weight.
I wanted to do something bc the doors u can knock off like 100lbs off the car by lightening them up (and im not talking about using fiberglass doors).
The power window motor weighs like 3lbs... maybe. Its very small. Now say you take out the glass in the door (heavy), the motor and the door support and anything else u didnt need you could see some decent weight savings. I however like my power windows! gona see if i can find a way to keep the power windows and lighten the door up a bit some how.
Old Feb 15, 2011 | 08:46 PM
dabird07's Avatar
Car: 92 firebird
hmmm never knew that!!!!
lol its funny watching my friends open the door!! lol they always hit something. . .
but is it easy gettin the dents out?? also
wheres a good place to find a paint kit?? ?(colors primar (cnt spell) clearcoat)
Old Feb 15, 2011 | 09:43 PM
Car: 87 TA clone
its not so funny when they ding your door or chip the paint on your door!
dents... hmmm never really had any, the door skins are pretty thin tho so it depends on how u try to remove the dents.
Paint kits? maybe eastwood? summit sells paint but ive never really seen any kits... except starter kits, but im pretty sure its just the guns, regulators, filters etc... paints are seperate. Car paint jobs arent super easy... youll need activators and thinners for the paint... drying cycles, angle/distance of the gun, too much paint =drips... theres alot going on. Also u need a paint booth (you can make your own but it should be free of dust etc.
Old Feb 15, 2011 | 10:03 PM
dabird07's Avatar
Car: 92 firebird
my friend is going to paint it doesnt have paint booth though so probly dust. . . didnt think of that. . .. .. man lol hes going to skool to do it and i wanna help him with his portfolio. . . .
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
1nastygta
Aug 8, 2015 07:38 PM
