Least Expensive Window Seals?
Car: 85 Camaro Z28
Engine: 5.7 TPI
I am looking for the least expensive place to purchase inner and outer window door seals.... the felt ones that run on the inside and outside of the door glass.... 1aauto seems to be the least expensive I can find, but was curious if you found a better deal somewhere.....
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Least Expensive Window Seals?
JY 4th gen sweeps, takes a little modding, but they work great I hear - there's several threads on it, just search "4th gen window sweeps".
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I see the outers every now and then on ebay. I bought a NOS GM set for $8.00+$4.00 shipping about 6 months ago. Just gotta be patient and lucky.
Dont know about the inners.
Good luck!
Good luck!
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
least expensive???you DO want to be pleased with your purchase dont you? least expensive means least attention to detail,it means they REQUIRE modding to work ,it means you spent good money for CRAP if you are ok with that you probably fix rust holes with duct tape
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
SPEEDY Z28
Sep 15, 2015 05:34 PM
blackandblue02
Sep 10, 2015 08:19 PM
