Rust hunt
Old Mar 31, 2011 | 12:28 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Rust hunt
A few weeks back I posted a pic under the title "rusty hole has me worried". It is a pic of the rust I found at the bottom of the unibody where the bottom of the fender mounts, just forward of the bottom door hinge. I don't know exactly what you call this area (some say bottom of the a-pillar, bottom of cowl drain.....whatever). Anyway, I couldn't figure out how moisture was getting in there and rotting out the rocker cavity, but I think this may have something to do with it. Now I'm sure I'm not the first to find this, but I think it's worth sharing. I picked out all the seam sealer in this area and found this huge gap between the seams....IDK..but I'm guessing water from the cowl drain was finding it's way back here past the sealer and causing the damage. I don't recall this issue on the passenger side, but the same area was rusted as well. I am now ripping out ALL the seam sealer I can get to. Hope this helps
Old Apr 1, 2011 | 01:07 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Rust hunt
Mine were much worse on both sides. I cut eveything out and welded in new metal, then reasealed it with seam sealer. That is a weak area on these cars. Most people have rust here but its hard to see until it gets really bad. Luckily mine is fixed and hopefully will last another 10 -20 years.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
