GTA Hood vents
Old Apr 4, 2011 | 07:32 PM
jak's Avatar
jak
GTA Hood vents
Hey guys ,
I have an 89 GTA that is finally going to see some paint..We stripped off all the ground effects lights and mirrors ..Only thing i have left is the hood vents .Anyone out there know how these come out.. The front two have bolts i see but the side ones , Close to the cowl dont appear to have bolts..Snap in? Any help is always appreciated..
Old Apr 4, 2011 | 08:12 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: GTA Hood vents
They snap in and are a nightmare only because many end up breaking. A small flashlight (metal in case you drop in and can use magnet to get back), and a flat head screw driver with a long handle will be what you need, and when you look in the tiny two holes next to the hood hinge mounting bolts, you should be able to get one easily, and one semi-hard. Do the semi-hard one first, so that you don't break that clip getting the easy one first after prying.
Old Apr 5, 2011 | 06:59 PM
jak's Avatar
jak
Re: GTA Hood vents
Thanks for the info it worked out well..Got them both off no broken pieces..
Old Apr 5, 2011 | 08:09 PM
84redta's Avatar
Re: GTA Hood vents
Glad it worked out great for you. Been a while since I had to do mine, but I remember they weren't fun, and everytime I see a hood in the yard, someone tries to grab them and always breaks them.
Hotrodboba400
Dec 10, 2019 07:07 PM
MantyZ28
Nov 8, 2015 06:54 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
