what to do about my wheel lip rust
Old Apr 13, 2011 | 09:32 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
Im hoping to get some suggestions for what i can do to fix these problem areas on my wheel wells. thanks in advance for your ideas.
Attached Thumbnails what to do about my wheel lip rust-sdc12459.jpg   what to do about my wheel lip rust-sdc12462.jpg   what to do about my wheel lip rust-sdc12464.jpg
Old Apr 13, 2011 | 10:31 PM
firehawk1988's Avatar
Car: Firebird Formula(1988 changed to 91
Engine: 355 TPI
Axle/Gears: 3.73(needs changed)
Re: what to do about my wheel lip rust
Is this on one side of the car or both?
Old Apr 13, 2011 | 11:11 PM
GreenieG's Avatar
Car: 1985 IROC-Z
both sides, both rear tires and 1 front
Old Apr 13, 2011 | 11:21 PM
Engine: 355 TPI
If the 3rd pic is the front fender, it looks like the dent could be pounded back out and the rust can be removed with a grinder(with flap disc) or a sander(40-80 grit). Or find a fender somewhere cheap and replace it.
The rear quarters are a different story and that would depend on your budget and skill level. Some might replace the quarter panel if its rotting out badly(you might find more rust once you start picking or grinding away on it). Or a person could weld in some patch panels after they are bent and formed close to the original shape. I have done this before and it takes time and patience to get it right.
The one thing you don't want to do is glob in alot of body filler to plug the holes.
Old Apr 13, 2011 | 11:25 PM
GreenieG's Avatar
Car: 1985 IROC-Z
ok cool yeah im asking because here in a month or two i wanna try to get this into the shop to get paint job.
morrow
Jan 13, 2024 12:29 PM
my86bird
Oct 23, 2015 12:20 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Aug 18, 2015 05:47 PM
