upper door hinge pins and bushings.
Old Apr 21, 2011 | 04:28 PM
dmosley73's Avatar
has anyone found a cheaper solution for the upper door hinge pins and bushings other than TDS ? i have been reading everyones posts and they all seem to be a few years old on this topic. i was just wondering if anyone has found a cheaper solution? thanks in advance
duane
83' z28 under construction
Old Apr 1, 2012 | 06:25 PM
kinomees's Avatar
Re: upper door hinge pins and bushings.
Sorry to use this thread but i have a similar problem. Since i am in Europe i can not afford the upper pin sets to be shipped here. Does anyone have info on the dimensions of the upper pins and holes? I have a machine shop next door and they are willing to fabricate the upper pins ans bushings. All i need is to give them the pin and hole measurements. I already replaced the lower ones that way and they turned out great!
Greetings
Old Apr 1, 2012 | 07:37 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
https://www.thirdgen.org/forums/afte...oor-hinge.html
Hotrodboba400
Dec 10, 2019 07:07 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
