electric rear hatch?
Old Apr 25, 2011 | 09:31 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Anyone know how to manually open these, if there is a way. Mine isnt really working since I pulled the motor for a 305 to 355 swap...
Old Apr 25, 2011 | 10:01 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: electric rear hatch?
It should still unlatch with the key. It just won't raise up if you don't have power.
Old Apr 26, 2011 | 02:19 AM
lizzybenny's Avatar
i know a little about it.I am not sure.
Old Apr 26, 2011 | 02:54 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
it will still unlock but you will not be able to get it closed again i noticed when my latch doesnt move upi cant lock it after i open it to open it manually you turn the key and lift the hatch up.
Old Apr 26, 2011 | 08:02 PM
Car: 87 Iroc
Engine: 350tpi
My key wont turn... hmm. will fool around with it more when the rain stops. thanks guys
Old Apr 26, 2011 | 08:07 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
take a bat charger and hook up the neg to the neg of the motor then clap the positive onto the positive only long enough for the motor to come up so you can latch it..
Old May 7, 2011 | 11:54 AM
Car: 87 Iroc
Engine: 350tpi
Ok. does anyone know where the motor for the hatch grounds? I still cant get it open, my key wont work. Hooking a battery up temporarily doesn't work either, though the battery will operate the power locks windows and everything else. My only guess is that it may have grounded to the heads, can anyone confirm?
Old May 12, 2011 | 08:24 PM
Car: 87 Iroc
Engine: 350tpi
bumpity? anyone have ideas?
Old Sep 5, 2011 | 12:59 AM
Car: 87 Iroc
Engine: 350tpi
Turns out it was just cause it wasnt grounded right. Didnt have the motor in so there wasnt a ground to it. The second I hooked up the block grounds it worked awesome.
Old Sep 20, 2011 | 12:12 AM
shawnhaynes's Avatar
what if its stuck in the up position, how do u get it back down manully?
Old Sep 20, 2011 | 07:06 AM
Engine: 383 SBC
If it has power then it should do it if the switch is toggled correctly and the striker (?), little lever on the top of the unit where the latch is pressed inward. If it doesn't check for power and check that your power connector on the drive housing (multi pin connector) is clean and in there solid. Mine had issues from time time with the connector vibrating loose a zip tie or 2 fixed that issue.
If you want to manually do it I think you would have to take the housing apart. There is a worm drive that controls the latch movement. I imagine trying to force it while all together would get you a broken housing, afterall the housing is plastic.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
