Replacement door?
Old May 13, 2011 | 11:47 AM
F_BodyMechE's Avatar
Replacement door?
I'm looking at a 91 GTA. The only thing wrong with it is the driver side door has a nasty dent and the spoiler is cracked. I have searched online for a good while now and have not found any third gen doors for less than $800+. I'm brand new to owning an F-body (I've loved them for a long time and now I'm finally buying one) so do you guys know of anywhere I can get body panels from?
Thanks!
Old May 13, 2011 | 11:56 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Replacement door?
http://thirdgenranch.com/-strse-Door...Categories.bok
http://www.hawksthirdgenparts.com/doorcomponents_1.aspx
Old May 13, 2011 | 12:00 PM
Sweet. Thank you. Google doesn't stand a chance against forum knowledge.
Old May 13, 2011 | 01:34 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Also familiarize your self with the local salvage yards that might be in your area. You can use a door off any trird gen Camaro or Bird. The spoiler will probably be found at Hawks easiest.
Old May 13, 2011 | 01:47 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
All 82-92 doors are basically the same besides mounting holes for ground effects. If you want to have an EXACT door match that you won't have to drill or modify for the ground effects, you'd need one off a 1991-92 Trans Am, GTA, or W68 (sport appearance package) Firebird. Needless to say, you're a lot more likely to find one on a base model Firebird with the W68 package.
Nonetheless, any door off any 1982-92 Camaro or Firebird model will bolt up and function properly.
$800 sounds stupid ridiculous high to me...is that for an entire car? The Pull-a-part here has 5-10 third gen's in stock at any given time, and sells doors for $27.
I got lucky on my spoiler, found someone on eBay that had original factory takeoffs with minor finish defects. Got one in as-new condition with nicer paint than my car for around $150/shipped. If you're going to pay the price for new and keep the car outside, I would HIGHLY recommend a fiberglass replacement for obvious reasons.
Old May 13, 2011 | 02:27 PM
91phoenix's Avatar
Very good point. I forgot all about the ground effect mounting holes. I am glad you mentioned it so he has more complete info. And I agree totally that $800 seems outrageous. That is why the suggestion of a pull a part or regular salvage yard. I don't have a pull a part near me. Even with freight it is much cheaper than that at Thirdgenranch.
Old May 13, 2011 | 03:33 PM
Engine: 383 SBC
Pull a part here only has 3 4th gens (all V6s) no 3rd gens. I was just there last weekend. Keep in mind if you find a 4th gen there are some parts that can also still be used (seats, some of the consoles, LS1 type driveshafts, etc), your doors will of course be different.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
