door sag
Old May 13, 2011 | 06:17 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
door sag
my door is saging badly and now its making it difficult to open and close i want to replace the bushings and pins but can you replace the top one? and if i cant will the bottom one alone fix the problem?
Old May 15, 2011 | 08:42 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: door sag
Yes.
http://www.top-downsolutions.com/doo...able-p-38.html
http://www.top-downsolutions.com/doo...able-p-37.html
Either of the kits I've linked will solve the problem. The greaseble assures that you are getting grease to the interface between the hinge pin and bushing better than you would by squirting it in from the exterior using an aerosol white lithium grease.
Lon
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
