windsheild washer nossles?
Old May 14, 2011 | 08:56 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
where can i get replacements? my driver side is broken and neither side really put out an fluid so i think they are clogged and i want new ones. so any suggestions?
Old May 14, 2011 | 09:38 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: windsheild washer nossles?
first , the problem with no fluid . check the output from the pump . then the lines from the pump to the blades . when all is good then to the arms . most of the time problems like this are from putting "tap water" in washer tank . a buildup of minerals in the water will plug/gum things up . a good way to clean old ones (nozzles) is a soak in common/cheap vinegar . as for the nozzles . i'm not really sure , GM used many different ones . i say this because i have several sets from different year camaro's , they are all different . just check J/Ys or dealerships . good luck .
Old May 14, 2011 | 10:14 PM
Engine: L31 350
i get fluid just not alot. iv got a new pump, new fluid, and new lines besides whats on the wiper arms.
Old May 14, 2011 | 11:30 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Try sticking a needle into the small outputs in the wiper fluid dispenser on the blades. Not only is that one way to aim the nozzles (for cars with nozzles on hoods) it could also be an effective way to fix the ones on yours. So try that first becasue it's bassically free but if ineffective then head to your local JY like TOM said.
Old May 15, 2011 | 02:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Do you have the early pump on wiper motor type?Those things fail too often.Had the same issues with only water dribbling out.Was always the pump takin a dump.
I went thru 6 or so before switching to the on tank style when i swapped to a 4th gen washer bottle.
I also decided on just one central nozzle between the wipers.
Bohemian
Aug 15, 2017 05:11 PM
Fireslash
Apr 11, 2016 06:43 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
Saxondale
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
