Floor Patching Progress
Old May 16, 2011 | 05:40 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
We probably should have given up on the car but what the hey... Here are some pics of the floor patching we have been doing. First some holes and the patching.
For the patching we used some heavy gauge metal (18 ish). Full perimeter welded with "spot" welds reproduced where required.
Attached Thumbnails Floor Patching Progress-242844_10150254979521469_675231468_9296417_1428521_o.jpg   Floor Patching Progress-242951_10150254978891469_675231468_9296384_4496204_o.jpg   Floor Patching Progress-220979_10150254979576469_675231468_9296420_8301422_o.jpg
Old May 16, 2011 | 05:44 PM
nosajwols's Avatar
Car: 82 Z28
Re: Floor Patching Progress
Once the patching was done the floors were painted with chassis saver paint and then seem sealed.
After that we sprayed them with truck bed liner. I predict that they will never rot again, OR someday I will be cursing what we did while patching them again...
After-all I was cursing the fact that 20 years ago we coated them with rubberized undercoating. It was a PITA to remove.
Attached Thumbnails Floor Patching Progress-221316_10150254979136469_675231468_9296397_1052858_o.jpg   Floor Patching Progress-240133_10150254978846469_675231468_9296383_4623187_o.jpg
Old May 18, 2011 | 10:21 AM
MD83Z's Avatar
Looks good...What type of welder do you use to attach those patches....I am guessing it is a wire feed with gas for heat...All I have is an old 220V stick
Old May 18, 2011 | 10:58 AM
nosajwols's Avatar
Car: 82 Z28
We used a MIG welder (~250 amp Miller) with a low "heat" setting.
Old May 18, 2011 | 12:45 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Nice I just patched the EXACT same places on mine.
Old May 18, 2011 | 03:16 PM
nosajwols's Avatar
Car: 82 Z28
For the front floor patches, this is the second time I have done them on this car in the exact same spot (the last time was ~20 years ago). I found some leaks in the cowl and where the strut towers meet the firewall (also patched these areas) so water was pooling here. (of course the usual T-Top leaks as well).
Old May 18, 2011 | 03:38 PM
midias's Avatar
Sounds familiar
Looks about the same huh?
LC2 TECH
Oct 13, 2015 11:53 PM
F-body-fan
Sep 19, 2015 09:02 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
