Difficulty with Fender bolts
Old May 17, 2011 | 11:38 AM
fissionfusion's Avatar
Car: 1985 Pontiac Trans Am
Engine: Chevy 350
Axle/Gears: GM 10 Bolt
Hey guys, got stuck trying to remove the bottom bolt that attaches the fender to the rest of the vehicle.
Question is, in your experiences what are the best ways to remove this thing? Previous owner probably crused the flap because I had to use vice grips to bend it away so I could even see the bolt, then I stripped the bolt in multiple failed attempts w/ WD40; but not so bad that a ratchet set couldn't grip.
Does anyone have some tips on removal of these bolts, provided I don't have a lot of space to work with? It's a regular 9/16th head with some sort of plastic type washer/nut on the bottom, not sure what you would call it.
Any help would be wonderful!
Old May 17, 2011 | 12:56 PM
startat2's Avatar
Re: Difficulty with Fender bolts
Are you talking about the one that barely has enough clearance to slip in and out? If so, I used a box wrench and took my time. When you think its almost out, wiggle the rest of your fender and see how close you are.
Old May 17, 2011 | 03:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Umm, for starters, it's a regular 13mm, not standard anything. Having the right wrench or socket would help. The ONLY 3 standard dimensioned bolts on the car are the 5/8" bolts on the steering gearbox, that's it. EVERYTHING else is metric.
And now you're going to have to use either a Bolt-Out or a hammer to get a socket on the bolt to get it out when you should have done it right in the first place.
Old May 19, 2011 | 11:17 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
If it is a 9/16" head then they have been changed out before because they are 13mm on my car. Though you say 9/16" I would wonder if they aren't 14 or 15 mm.
Old May 25, 2011 | 10:23 AM
cimism610's Avatar
Does anyone know how to replace the entire mount where the fender bolts on. I bottomed out my car and its going to be toast soon. Does anyone sell it.
morrow
Jan 13, 2024 12:29 PM
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
