Pop out a dent in the nose?
Old May 25, 2011 | 09:20 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
I've enclosed pics of my front nose which has a dent in it. My question is can this be pulled out or at least made not to look so gawdy. I tried pushing it up from underneath to no avail. How would you remove dent from plastic? Any suggestions?
Attached Thumbnails Pop out a dent in the nose?-100_0754.jpg   Pop out a dent in the nose?-100_0757.jpg
Old May 25, 2011 | 09:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Pop out a dent in the nose?
the nose is plastic, if nothing is torn, it should pop out. If its been bent like that for a long time, it may not come out completely if at all.
i doubt you can get completely behind that part of the nose without removing the nose from the car.
Old May 25, 2011 | 09:40 PM
macmatt's Avatar
Engine: 305 TBI
I couldn't exactly get behind it I just went through the nose from the bottom. There was enough of an opening to get a pry bar up there to try and push it out. Which didn't do me any good. Pop it out and it pops right back in.
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
maybe try a heat gun or blow dryer BUT DO NOT GET TO CLOSE TO PAINT get the plastic nice and warm and if can get something under that part to hold dent part out maybe it will take shape again but idk if it will work or not
Old May 25, 2011 | 09:47 PM
macmatt's Avatar
Engine: 305 TBI
well that certainly couldn't hurt. I'm not worried about the paint. It's chipped, cracked and broken anyway. Plus I'll be getting a new nose and new paint next year. Just figured I'd try it so it wouldn't start to resemble a catfish face like an geo storm. I may need to replace the part that supports the nose that's in front of the radiator because it's bent in a little on that side.
Old May 25, 2011 | 10:08 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
You should remove the nose from the car and use a heat gun to reshape the area.
RS Reaper
Oct 17, 2018 07:52 PM
meeklay812
Oct 1, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
