ANYBODY EVER SEEN A BUSHING / PIN KIT FOR UPPER HINGES
Old May 28, 2011 | 11:35 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
MY UPPER HINGES ARE WORN OUT. IVE NEVER SEEN A BUSHING / PIN KIT TO FIX EM. ANYBODY EVER SEEN ONE??
Old May 28, 2011 | 11:50 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: ANYBODY EVER SEEN A BUSHING / PIN KIT FOR UPPER HINGES
Try the vendors on this site.
Hawks
http://www.hawksthirdgenparts.com/doorcomponents_1.aspx
TDS
http://www.top-downsolutions.com/bod...83929320759ae4
Old May 28, 2011 | 02:01 PM
DRIVE2FAST's Avatar
Originally Posted by TTOP350
KOOL. THANX.
Old May 28, 2011 | 11:11 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
drive, i have the cheaper non greaseable kit in my car and i was pleased with it. one thing i sugguest, ither go to your local parts store or get one thru Lon at TDS, the door spring tool. getting it out is no issue, going in, thats a whole diff battle.
be sure to have the WHOLE spring in the jaws when re installing.
Old May 28, 2011 | 11:30 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I also used the non greasable kit from Top Down Solutions and worked great and having the door spring tool is some really good advice.
Old May 28, 2011 | 11:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have the TDS kit in both my dorrs and havent had one ounce of trouble with them in 5 years. My doors also have dynamat in them so they are a bit heavier then a stock door.
Old Jun 1, 2011 | 02:22 PM
JSUPreston's Avatar
I got the full greasable kit from Lon/TDS for both doors last week. Only did the driver's side door over the weekend. I wound up having to take the door off to grind out the uppen pins (or whatever crap GM wants to call it). Got door reinstalled with just a little help from my father-in-law. Works great, and I haven't even greased it yet! Did discover that the spring is missing. Probably from the previous owner.
The OEM bushings in mine were practically gone! I had just enough of the upper bushings to see that there were some at one time.
I thought about the non-grease kit, but decided to opt to spend the little extra and get the really nice stuff.
Just FYI, I used quite a few discs on my single speed dremel. I also used a hammer chisel (without the hammer...the bit was left in my shop by a previous home owner), a punch and an angle grinder w/4" disc. Unless something is really out of whack, the kit from TDS should have all the instructions and answers. If you run into problems or have questions, Lon responded to my e-mails very quickly, which is one of the reasons why I bought through him.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
