GTA ground effects removal
Old Jun 8, 2011 | 03:34 AM
Mauiform's Avatar
O.K. So I went through quite a bit of threads about adding ground effects to base models. How about removing them? Has anyone permanently removed them from their TA/GTA? Reason for the question is that I'm considering creating a Formula 350/GTA hybrid.
-Bobby
Old Jun 8, 2011 | 06:50 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Re: GTA ground effects removal
The cars that came with ground effects have a tab on the side for them. Runs under the doors. It would look like crap unless you took that off and repainted the sides.
You can see some of it in my pic below.
Old Jun 8, 2011 | 06:51 AM
rdhanded2's Avatar
Top Answer: 1
Also, you would have a lot of holes to weld up as well, but that is not that bad.
Old Jun 9, 2011 | 12:59 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Then you will need to swap out the front and rear bumper covers as these had the ground effects molded in. The driving/fog lights will not fit the same if at all.
I am not sure about 82-84 but sure about 85-92 bumper covers. The driving lights on a 91-92 bumper will still fit though.
Remove the metal strip on the rocker panels and fill all the holes and you would be all set.
Old Jun 9, 2011 | 07:39 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
if those ground effects are in good shape you got a buyer right here! I need the driver and passenger sides BAD!
Old Jun 10, 2011 | 07:26 AM
Mauiform's Avatar
GTA fans REJOICE! I found a nice '89 Formula 350. No need to destroy the GTA.
-Bobby
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
