IROC light question
Car: 1985 IROC-Z
Transmission: T5 manual
IROC light question
hi i just got a 85 iroc and i was wanting to know if on irocs are all 4 lamps supposed to come on when you switch to hi beams? im asking because when the low beams are on the outer lamps work fine but when i switch to hi beams only the 2 on the drivers side come on and the passenger side stays dark. do I need to just replace the passenger side lamps then?
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: IROC light question
Wait,,
Both lamps on the passenger side stay dark on the hi beams but the passenger side low beam works without the hi switch on??
Car: 1985 IROC-Z
no im sayin low beams work normal but when i turn on the hi beams the driver side outer and inner lamps come on while the passenger side goes dark for both lamps.
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
then you need to replace the passenger side light. its light having half a light out. like sometimes you see people brake and the light goes out. same thing. half the filament burnt out
mustangman65_79
Aug 11, 2015 03:17 PM
