power hatch lock not working?
Old Jun 20, 2011 | 09:19 PM
HiG4s's Avatar
Engine: 86 Trans AM
Transmission: 5M
Axle/Gears: ?? 2:77 I think??
The power hatch on my 86 TA opens fine from the button on the dash, but when I put the door key in the rear lock, it doesn't turn very far. I assume it should turn about 1/4 turn to release the hatch. Not sure if it is not the right key, or just the lock is broken..
I pulled the inside panel off and can see where it is riveted, but do not see how to get the center section of the plastic between the tail lights off to get at it. I also am assuming that it is just an electrical switch (like on the dash) that needs a key to make the contacts.
Any info from those in the know would be appreciated.
Old Jun 21, 2011 | 01:03 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: power hatch lock not working?
The key turns and pulls a short cable that goes to the same mechanism the solenoid pulls on. Assuming it's the right key it may just need lubing.
Old Jun 21, 2011 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Try a shot of Lock-Ease before you do anything drastic. That said, I once had a door lock cylinder which was frozen and required replacement.
JamesC
Old Jun 23, 2011 | 05:25 PM
HiG4s's Avatar
Engine: 86 Trans AM
Transmission: 5M
lubing the lock has not helped. I can get a new power lock cylinder with key for $29, but I still cannot figure out how to get the center section between the taillights out to get to the lock and wiring!
Old Jun 23, 2011 | 05:30 PM
HiG4s's Avatar
Engine: 86 Trans AM
Transmission: 5M
Never mind, just found a link on how to remove it.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
